I have connected an empty 16GB USB drive to my OSMC Raspberry 2B containing an 8GB SD with the intention of backing up the settings before flashing a new larger card and restoring the settings.
I am getting an error that there is insufficient space.
This doesn’t make sense?
The Raspberry itself only has 24MB left - I’m not sure if this is the issue?
What should I do?
Thanks.
That is the issue as the backup script creates first a backup file on the card before moving it to the backup media.
Two options you have:
Use backup script from @grahamh [How to] Make periodic backups of whole OSMC system
Make a 1:1 copy of the SD card onto the new card and then increase the partition size to the full 16GB with gparted.
Option 3: install OSMC on the new card, boot up and copy across /home/osmc/ from the old card using a card reader.
