Just Upgraded to Vero 4k+ from Pi. Can I just pull out the SD card from the Pi and insert it into the Vero? Then I am good to go? Thanks!
No — but you can use the My OSMC backup tool to copy everything over
You won’t be running the OS from the SD card. But you can copy /home/osmc/.kodi across to get your settings from the Pi.
And any media.
Many thanks!!
