Hello,
I’m upgrading my Edimax EW-7811un to a EW-7822ulc and the ulc doesn’t seem to work.
Now I’ve tested the ulc and it works on my debian box.
Ok so here are the particulars working system with the 7811un: http://paste.osmc.io/poqulojufa
now just for fun I will show you the output of lsmod and lsusb
lsusb
osmc@osmc:~$ lsusb
Bus 001 Device 008: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 007: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 006: ID 050d:706a Belkin Components 2-N-1 7-Port Hub (Upper half)
Bus 001 Device 005: ID 14cd:6116 Super Top M6116 SATA Bridge
Bus 001 Device 004: ID 050d:0706 Belkin Components 2-N-1 7-Port Hub (Lower half)
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
osmc@osmc:~$
As you can see the 7811un is clearly visible
now the lsmod
osmc@osmc:~$ lsmod
Module Size Used by
bnep 12310 2
hci_uart 22713 1
btbcm 8478 1 hci_uart
bluetooth 425568 22 bnep,btbcm,hci_uart
joydev 9585 0
evdev 13192 2
8192cu 640986 0
brcmfmac 234779 0
hid_logitech_hidpp 15243 0
bcm2835_thermal 2541 0
bcm2835_gpiomem 4026 0
hid_logitech_dj 12935 0
brcmutil 9348 1 brcmfmac
snd_bcm2835 24938 0
sg 23925 0
cfg80211 565548 1 brcmfmac
rfkill 22502 6 cfg80211,bluetooth
snd_pcm 115812 1 snd_bcm2835
snd_timer 26094 1 snd_pcm
uas 16127 0
snd 78512 3 snd_bcm2835,snd_timer,snd_pcm
bcm2835_wdt 4081 0
uio_pdrv_genirq 3885 0
uio 10428 1 uio_pdrv_genirq
fuse 108681 1
ipv6 448018 42
osmc@osmc:~$
This is on a pi3 so I have wlan0 (pi3 onboard) and wlan1 (7811un)
Now I’ll add the 7822ulc: http://paste.osmc.io/oficefulup
lsusb
osmc@osmc:~$ lsusb
Bus 001 Device 009: ID 7392:b822 Edimax Technology Co., Ltd
osmc@osmc:~$
The new adapter is seen
lsmod
osmc@osmc:~$ lsmod
Module Size Used by
bnep 12310 2
hci_uart 22713 1
joydev 9585 0
evdev 13192 2
8192cu 640986 0
brcmfmac 234779 0
snd_bcm2835 24938 0
sg 23925 0
uas 16127 0
bcm2835_wdt 4081 0
fuse 108681 1
ipv6 448018 42
osmc@osmc:~$
I still have only wlan0 and wlan1
now just for kicks I will reboot and see if that makes the ulc work
no, it does not look like it changed anything: http://paste.osmc.io/wumacuhako
osmc@osmc:~$ lsusb
osmc@osmc:~$ lsmod
Module Size Used by
bnep 12310 2
hci_uart 22713 1
joydev 9585 0
evdev 13192 2
8192cu 640986 0
brcmfmac 234779 0
sg 23925 0
uas 16127 0
snd_bcm2835 24938 0
bcm2835_wdt 4081 0
fuse 108681 1
ipv6 448018 42
osmc@osmc:~$
Hmmm… since I have an onboard wifi, let me just boot osmc with the ulc only.
http://paste.osmc.io/tixatelesi
osmc@osmc:~$ lsusb
Bus 001 Device 008: ID 7392:b822 Edimax Technology Co., Ltd
osmc@osmc:~$ lsmod
Module Size Used by
bnep 12310 2
hci_uart 22713 1
brcmfmac 234779 0
joydev 9585 0
evdev 13192 2
snd_bcm2835 24938 0
sg 23925 0
rfkill 22502 5 cfg80211,bluetooth
uas 16127 0
bcm2835_wdt 4081 0
fuse 108681 1
ipv6 448018 42
osmc@osmc:~$
