Upload vidodb.xml
I just completed the installation of osmc on RPi 2 and it’s great !!! congratulation to the developers for this marvel !!! I’ve got only an issue in order to upload movies DB:
I cannot see videodb.xml into the import menu, i’ve downloaded xml and modified manually, I copied to /home but no way, no files appear on menu upload…
Any idea ??
Thanks in advance for help
Hi there,
I am having the exact same issue. I’d really like some help with this if anyone knows why this is happening?
Thanks,
Dave
Bump
I’m also having the same issue…
What are you trying to do and what have you done?
I’m trying to import my video dB from a single file export done on raspbmc.
