I’m trying to set up UPnP library share again from my Pi2 to my PiB.
Setting this up via “Title” works for TV Shows but NOT with Movies. Selecting “Title” for the movies it just times out adding the UPnP source. All the other options work ie; genre etc.
Was working fine under Alpha 4 and RC but trying this again with RC2 it doesn’t work.
13 days without a reply means nobody here knows the answer to your question, so continuing to bump the thread is not going to help and is not good netiquette.
This type of issue is almost certainly a bug in Kodi itself and not specific to OSMC. Whilst it might have been working in Alpha 4 keep in mind that Alpha 4 was using an earlier version of Kodi, so the bug may have been introduced in a recent update of Kodi, and is probably only an OSMC bug in as much as we now ship a later version of Kodi than we previously did.
You’ll find a lot more people in the Kodi forum and for Kodi specific problems like this you’re likely to get more responses due to the sheer number of users on the that forum.
They are onto it in the Kodi forums @DBMandrake but it looks like an isolated issue for some reason or most people don’t library share or it is indeed a bug.
I was wondering if there may be some issue with my UPnP xml file or files. Is it possible to remove the xml files and they are then created freshly again on a restart?
Basically what I am trying to achieve is a clean slate with UPnP rather than having to complete two new fresh install.
@DBMandrake, in the Kodi forum they advised that my setup is looking for external subtitles via UPnP. They recommended me to turn this setting off.
I can find no references in my searches for such a setting in Kodi 14.2 only for Isengard.
There is definitelty something strange going on. If I use the PiB as the server and Pi2 as the client it works fine. Unfortunately I need the Pi2 to be the server and the PiB to be the client.
