UPNP not working in 2023.12-1
Hello!
I had to find out that UPNP is not working any more in the latest release.
It is possible to add a source doing “browse”, but afterwards no content is displayed.
In 2023.08-1 this works fine.
regards
CDS
There’s a separate thread on this issue. The short version is that you can wait for the fix or try the Mezzmo Kodi addon in UPnP mode.
Thanks,
Jeff
That thread found that it was a skin issue with the OSMC skin, correct? So why no suggestion to just use Estuary for a few days? I don’t think the wait should be too long. Chillbo thinks that he should be in staging within days and Sam is keen to push a skin update to stable on an expedited schedule assuming nothing unexpected crops up in testing.
