You are mistaken. SPDIF supports only two PCM channels regardless of device. To get multichannel you have to use AC3 or DTS. You simply need to set your audio settings such (switch to expert view so you can see everything) that channels is 2.0, passthrough is enabled and set to that output device and enable AC3, transcoding, and DTS if your AVR supports it. Do not enable the HD audio options as they are not supported with this connection and I assume your hardware. You can find more information in the following thread.
I tried the settings noted, however the decoder still reports the stream as pro logic instead of AC3. The same movie played through Kodi on an xb1 via the same optical cable plays back as AC3. Thoughts?
Login to OSMC via ssh and Install mediainfo sudo apt-get install mediainfo and then run mediainfo <File>
Afterwards share the info here using </> format button.
Thx for your help.
reproduce the issue
When you have provided the info @fzinken has asked for, I would be interested to find out why you had difficulty with the Cm 6206 device. It should work. So if you have a moment, as a separate exercise can you plug the device in and post logs for that. One possibility is it’s drawing too much power from the USB port.
I finally had a chance to revisit this and having reapplied the right settings, I’m able to get DD and DTS on my old speaker setup
Due to this great news and awesome support from this forum, I’ll b ordering a second Vero 4+ later on today. Thanks all
