USB audio sample rate, again
Hi, I saw this thread: USB Audio sample rate - #9 by grahamh
I have a similar CM106 USB audio card.
The connection I want is RPi4->USB->CM106->TOSLink->Receiver->Speakers.
The purpose is for routing a large number of audio inputs through the receiver and switching them there. The receiver decodes DD 5.1 and DTS.
If I use “Best” or “Optimal” in the audio settings, everything is working fine on multichannel audio streams that are passed through to the receiver. However, in the OSD menu and on 2-channel sources (e.g. YouTube plugin), I get about 10Hz annoying clicking in the audio output.
If I use “Fixed” with Limit set to 48KHz, there is no clicking. However, by doing so, I lose the Passthrough option. All audio is downmixed to 2-channel PCM so there is nothing for the receiver to decode.
On that sound card I tried selecting the default output, the ‘surround21’ output and the ‘SPD/IF’ output with similar results.
I’m thinking that what I need is to select a fixed sample rate for downmixed output only (since based on my experiments the USB DAC seems only tolerant of 48KHz, despite what it advertises), but still passing through multichannel streams without transcoding/resampling.
The sound card advertises:
2025-06-20 22:39:00.126 T:634      info <general>: CAESinkALSA::EnumerateDevice - device sysdefault:CARD=vc4hdmi0 description vc4-hdmi-0, MAI PCM i2s-hifi-0
                                                   Default Audio Device
2025-06-20 22:39:00.127 T:634      info <general>: CAESinkALSA::EnumerateDevice - device hdmi:CARD=vc4hdmi0,DEV=0 description vc4-hdmi-0, MAI PCM i2s-hifi-0
                                                   HDMI Audio Output
2025-06-20 22:39:00.137 T:634      info <general>: CAESinkALSA::EnumerateDevice - device sysdefault:CARD=ICUSBAUDIO7D description ICUSBAUDIO7D, USB Audio
2025-06-20 22:39:00.154 T:634      info <general>: CAESinkALSA::EnumerateDevice - device @:CARD=ICUSBAUDIO7D,DEV=0 description ICUSBAUDIO7D, USB Audio
                                                   Front output / input
2025-06-20 22:39:00.167 T:634      info <general>: CAESinkALSA::EnumerateDevice - device surround21:CARD=ICUSBAUDIO7D,DEV=0 description ICUSBAUDIO7D, USB Audio
                                                   2.1 Surround output to Front and Subwoofer speakers
2025-06-20 22:39:00.168 T:634      info <general>: CAESinkALSA::EnumerateDevice - device iec958:CARD=ICUSBAUDIO7D,DEV=0 description ICUSBAUDIO7D, USB Audio
                                                   IEC958 (S/PDIF) Digital Audio Output
2025-06-20 22:39:00.169 T:634      info <general>: CAESinkALSA - Unable to open device "sysdefault:CARD=vc4hdmi1" for playback
2025-06-20 22:39:00.170 T:634      info <general>: CAESinkALSA - Unable to open device "hdmi:CARD=vc4hdmi1,DEV=0" for playback
2025-06-20 22:39:00.171 T:634      info <general>: Found 1 Lists of Devices
2025-06-20 22:39:00.171 T:634      info <general>: Enumerated ALSA devices:
2025-06-20 22:39:00.171 T:634      info <general>:     Device 1
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceName      : sysdefault:CARD=vc4hdmi0
2025-06-20 22:39:00.171 T:634      info <general>:         m_displayName     : vc4-hdmi-0
2025-06-20 22:39:00.171 T:634      info <general>:         m_displayNameExtra: MAI PCM i2s-hifi-0
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceType      : AE_DEVTYPE_PCM
2025-06-20 22:39:00.171 T:634      info <general>:         m_channels        : FL, FR
2025-06-20 22:39:00.171 T:634      info <general>:         m_sampleRates     : 32000,44100,48000
2025-06-20 22:39:00.171 T:634      info <general>:         m_dataFormats     : AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
2025-06-20 22:39:00.171 T:634      info <general>:         m_streamTypes     : No passthrough capabilities
2025-06-20 22:39:00.171 T:634      info <general>:     Device 2
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceName      : hdmi:CARD=vc4hdmi0,DEV=0
2025-06-20 22:39:00.171 T:634      info <general>:         m_displayNameExtra: SEC EPSON PJ on HDMI
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceType      : AE_DEVTYPE_HDMI
2025-06-20 22:39:00.171 T:634      info <general>:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8,AE_FMT_RAW
2025-06-20 22:39:00.171 T:634      info <general>:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2025-06-20 22:39:00.171 T:634      info <general>:     Device 3
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceName      : @:CARD=ICUSBAUDIO7D,DEV=0
2025-06-20 22:39:00.171 T:634      info <general>:         m_displayName     : ICUSBAUDIO7D (@:CARD=ICUSBAUDIO7D,DEV=0)
2025-06-20 22:39:00.171 T:634      info <general>:         m_displayNameExtra: Analog
2025-06-20 22:39:00.171 T:634      info <general>:         m_channels        : FL, FR, FC, LFE, SL, SR, BL, BR
2025-06-20 22:39:00.171 T:634      info <general>:         m_sampleRates     : 48000
2025-06-20 22:39:00.171 T:634      info <general>:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE
2025-06-20 22:39:00.171 T:634      info <general>:     Device 4
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceName      : surround21:CARD=ICUSBAUDIO7D,DEV=0
2025-06-20 22:39:00.171 T:634      info <general>:         m_displayName     : ICUSBAUDIO7D (surround21:CARD=ICUSBAUDIO7D,DEV=0)
2025-06-20 22:39:00.171 T:634      info <general>:         m_channels        : FL, FR, BL, BR, FC, LFE, SL, SR, UNKNOWN1, UNKNOWN2, UNKNOWN3, UNKNOWN4, UNKNOWN5, UNKNOWN6, UNKNOWN7, UNKNOWN8
2025-06-20 22:39:00.171 T:634      info <general>:         m_sampleRates     : 44100,48000
2025-06-20 22:39:00.171 T:634      info <general>:     Device 5
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceName      : iec958:CARD=ICUSBAUDIO7D,DEV=0
2025-06-20 22:39:00.171 T:634      info <general>:         m_displayNameExtra: S/PDIF
2025-06-20 22:39:00.171 T:634      info <general>:         m_deviceType      : AE_DEVTYPE_IEC958
2025-06-20 22:39:00.171 T:634      info <general>:         m_sampleRates     : 44100,48000,96000
2025-06-20 22:39:00.171 T:634      info <general>:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S16NE,AE_FMT_S16LE
2025-06-20 22:39:00.171 T:634      info <general>:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
2025-06-20 22:39:00.172 T:634   warning <general>: ValidateOutputDevices: audio output device setting has been updated from 'ALSA:@:CARD=ICUSBAUDIO7D,DEV=0|ICUSBAUDIO7D (@:CARD=ICUSBAUDIO7D,DEV=0) (ICUSBAUDIO7D)' to 'ALSA:@:CARD=ICUSBAUDIO7D,DEV=0|ICUSBAUDIO7D (@:CARD=ICUSBAUDIO7D,DEV=0)'
2025-06-20 22:39:00.180 T:635      info <general>: CActiveAESink::OpenSink - initialize sink
2025-06-20 22:39:00.180 T:635      info <general>: CAESinkALSA::Initialize - Attempting to open device "@:CARD=ICUSBAUDIO7D,DEV=0"
2025-06-20 22:39:00.187 T:635      info <general>: CAESinkALSA::Initialize - Opened device "surround40:CARD=ICUSBAUDIO7D,DEV=0"
2025-06-20 22:39:00.187 T:635      info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2025-06-20 22:39:00.187 T:635      info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S16NE
Does it work as expected under Raspberry Pi OS?
By that you mean testing with basic tools like aplay at different sample rates?
Or Kodi under RPI OS…
But under the ALSA pipeline, not PulseAudio or Pipewire…
