I am interested in troubleshooting OSMC usb automount process/configuration/rules.
Does anybody know how is OSMC getting usb automount?
OSMC is using udisk for automount
Generally should work fine if you have a supported Filesystem and the Filesystem is clean and it has a proper label.
To debug open a ssh session and run sudo journalctl -f then plug in the drive
Thank you!
