USB controller dies after plugging in remote dongle
I have a Vero 4K+ and there are two USB devices connected to it:
  1. the USB dongle of the supplied remote
  2. an external HDD connected through a self-powered USB hub.
Two days ago the remote control stopped working. After changing batteries, trying to pair again, and troubleshooting a while, I narrowed down the problem to the USB dongle. Whenever I plug it in, the whole USB controller seems to halt, and the following is visible in the logs:
May 15 10:26:09 osmc kernel: xhci-hcd xhci-hcd.0.auto: xHCI host not responding to stop endpoint command.
May 15 10:26:09 osmc kernel: xhci-hcd xhci-hcd.0.auto: Assuming host is dying, halting host.
May 15 10:26:09 osmc kernel: xhci-hcd xhci-hcd.0.auto: HC died; cleaning up
The full logs can be found here: https://paste.osmc.tv/yuciroxije
The external HDD also becomes unavailable after this.
What can be the problem? May the USB dongle of the remote cause such an issue? Can I replace the USB dongle or should I buy a new remote?
Best regards,
Viktor
After you have carefully inspected the USB port and the USB dongle and have ruled out that dirt or a bent signal contact is the cause of the problem, buying a new remote control would be the way to go.
Btw.: I love my ’ Rii Mini i8+’ remote control (it’s a mini keyboard) with the Veros so much. It’s now operating since years and never caused any issue.
Have you tried without the hard drive attached?
Yes, I tried without the USB hub and HDD attached, the result is the same.
Does the receiver work in a PC?
I tried the receiver in a linux laptop. First it was recognized, lsusb showed it as “OSMC Remote Controller USB Keyboard Mouse”. I tried to get something out of it using the remote. After a few minutes I unplugged the receiver, then plugged it in again, but this time it was not recognized, lsusb did not show it. When I took it out from the USB port the receiver felt somewhat hot. After that I couldn’t make it be recognized.
OK, let’s not do any more tests like that
If you ping sales@osmc.tv with a link to this thread and order # I can see if we have replacement USB receivers available for your model.
