I am using vero4k, omsc kodi 19 testing, tvheadend pvr with usb dvb sky 360 and a IR LG magic remote with lirc disabled.
The remote works as expected until I play Live TV in kodi. Then 98% of IR events are lost. As soon as I stop Live TV, IR works normally. I verified with “ir-keytable -t” so specific kodi or eventlircd issue is discarded as well as lirc which I am not using anyway. CPU usage can spike to 75%, this does not seem high enough to be an issue. Any hints?
Happened to me as well with osmc stable but did not have the chance to troubleshoot a lot on that setup but I guess this is not specific to the kodi 19 testing branch.
reproduce the issue
What happens if you watch other content, like a film?
If you can use ir-keytable, I assume you’re familiar with CLI. What’s top look like – is the CPU pegged?
Watching a film, the remote works fine. CPU load also looks fine while watching Live TV, after more than 15 minutes of Live TV: load average: 1.08, 0.92, 0.80.
The driver has an option to disable the dvb IR and I am making use of it, only the vero IR receiver is enabled.
