Hello!
I’ve successfully set up my OSMC, using:
- Raspberry Pi 3 Model B+
- TVHeadend from the App Store
- USB DVB-T stick Omega T900, which is based on IT9135
I can watch Live TV, etc.
However, sometimes when I reboot (Kodi → Power → Reboot), the USB stick is not recognised by the OS and disappears from TVHeadend’s web UI, and as a result, the channels in the PVR & Live TV do not work and show the error “No adapter” (or something, I’m not using Kodi in English).
Here are the last (relevant) lines of dmesg after a reboot when it is failing:
[ 6.212312] usb 1-1.3: USB disconnect, device number 4
[ 6.543629] nf_conntrack version 0.5.0 (12288 buckets, 49152 max)
[ 7.098281] random: crng init done
[ 7.335231] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.361701] usb 1-1.1.3: dvb_usb_v2: 2nd usb_bulk_msg() failed=-110
[ 7.361740] dvb_usb_af9035: probe of 1-1.1.3:1.0 failed with error -110
[ 7.361819] usbcore: registered new interface driver dvb_usb_af9035
[ 7.376615] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.376629] brcmfmac: power management disabled
[ 7.835161] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 11.612207] Console: switching to colour dummy device 80x30
Note that on other occasions the message USB disconnect, device number 4 appears last. This particular time the order is somewhat random, but this is the one I managed to capture while posting this message.
And here is the output of dmesg | grep dvb after a reboot when it is working fine:
[ 5.375067] dvb_usb_af9035 1-1.1.3:1.0: prechip_version=83 chip_version=02 chip_type=9135
[ 5.382690] usb 1-1.1.3: dvb_usb_v2: found a 'ITE 9135(9005) Generic' in cold state
[ 5.455261] usb 1-1.1.3: dvb_usb_v2: downloading firmware from file 'dvb-usb-it9135-02.fw'
[ 5.545395] dvb_usb_af9035 1-1.1.3:1.0: firmware version=3.40.1.0
[ 5.545427] usb 1-1.1.3: dvb_usb_v2: found a 'ITE 9135(9005) Generic' in warm state
[ 5.545965] usb 1-1.1.3: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
[ 5.546061] dvbdev: DVB: registering new adapter (ITE 9135(9005) Generic)
[ 5.662028] usb 1-1.1.3: dvb_usb_v2: schedule remote query interval to 500 msecs
[ 5.662035] usb 1-1.1.3: dvb_usb_v2: 'ITE 9135(9005) Generic' successfully initialized and connected
[ 5.662121] usbcore: registered new interface driver dvb_usb_af9035
In both cases, lsusb shows the device as Integrated Technology Express, Inc..
When it is failing, If I unplug the USB stick and then plug it in and restart tvheadend, the adapter is detected and I can watch Live TV. However, that is not very convenient if I want to just stick the RPi behind my TV.
So, what is going on? Is there anything I can do or try to fix this?
