Will provide OSMC log files soon.
Where/how do I get server’s system journal?
Which OS are you running on the server?
Generically for modern linux systems sudo journalctl
should work.
Latest Raspberry PI OS.
Thanks, will check if command works when I’m at home.
TVheadend Server, RPI with Raspberry PI OS, journal log:
journalctl
Jan 19 15:07:04 raspberrypi kernel: bcm2835_v4l2: Unknown symbol v4l2_ctrl_log_status (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_v4l2: disagrees about version of symbol video_device_release_empty
Jan 19 15:07:04 raspberrypi kernel: bcm2835_v4l2: Unknown symbol video_device_release_empty (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_v4l2: disagrees about version of symbol v4l2_event_unsubscribe
Jan 19 15:07:04 raspberrypi kernel: bcm2835_v4l2: Unknown symbol v4l2_event_unsubscribe (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_v4l2: disagrees about version of symbol vb2_ioctl_reqbufs
Jan 19 15:07:04 raspberrypi kernel: bcm2835_v4l2: Unknown symbol vb2_ioctl_reqbufs (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_queue_init
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_queue_init (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_devnode_remove
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_devnode_remove (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_core_expbuf_dmabuf (err -2)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol video_ioctl2
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol video_ioctl2 (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_device_unregister
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_device_unregister (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_queue_release
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_queue_release (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_streamoff
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_streamoff (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_device_init
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_device_init (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_expbuf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_expbuf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_ctrl_handler_init_class
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_ctrl_handler_init_class (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_dma_contig_memops
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_dma_contig_memops (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol __media_device_register
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol __media_device_register (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_querybuf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_querybuf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_fh_open
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_fh_open (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_create_intf_link
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_create_intf_link (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_entity_remove_links
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_entity_remove_links (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_create_pad_link
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_create_pad_link (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol video_devdata
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol video_devdata (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_fop_release
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_fop_release (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_device_register_entity
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_device_register_entity (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_device_cleanup
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_device_cleanup (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_dqbuf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_dqbuf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_create_bufs
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_create_bufs (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_ctrl_new_custom
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_ctrl_new_custom (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_prepare_buf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_prepare_buf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_buffer_done
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_buffer_done (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_plane_vaddr
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_plane_vaddr (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_ctrl_subscribe_event
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_ctrl_subscribe_event (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_entity_pads_init
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_entity_pads_init (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol video_unregister_device
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol video_unregister_device (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_event_subscribe
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_event_subscribe (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_qbuf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_qbuf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_fop_mmap
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_fop_mmap (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_remove_intf_links
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_remove_intf_links (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_device_register
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_device_register (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol __video_register_device
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol __video_register_device (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_streamon
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_streamon (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_fop_poll
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_fop_poll (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_ctrl_new_std
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_ctrl_new_std (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_ctrl_handler_free
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_ctrl_handler_free (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_device_unregister
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_device_unregister (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_wait_for_all_buffers
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_wait_for_all_buffers (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_devnode_create
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_devnode_create (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol media_device_unregister_entity
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol media_device_unregister_entity (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol video_device_release_empty
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol video_device_release_empty (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol v4l2_event_unsubscribe
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol v4l2_event_unsubscribe (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: disagrees about version of symbol vb2_ioctl_reqbufs
Jan 19 15:07:04 raspberrypi kernel: bcm2835_isp: Unknown symbol vb2_ioctl_reqbufs (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol vb2_queue_init
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol vb2_queue_init (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_fh_exit
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_fh_exit (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_job_finish
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_job_finish (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol vb2_core_expbuf_dmabuf (err -2)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol video_ioctl2
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol video_ioctl2 (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol media_device_unregister
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol media_device_unregister (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol media_device_init
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol media_device_init (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_fh_del
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_fh_del (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ctx_release
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ctx_release (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_fh_add
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_fh_add (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol vb2_ops_wait_finish
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol vb2_ops_wait_finish (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_buf_remove
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_buf_remove (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_src_change_event_subscribe
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_src_change_event_subscribe (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_ctrl_handler_init_class
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_ctrl_handler_init_class (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol vb2_dma_contig_memops
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol vb2_dma_contig_memops (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol __media_device_register
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol __media_device_register (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_expbuf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_expbuf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_querybuf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_querybuf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_ctrl_handler_setup
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_ctrl_handler_setup (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_buf_queue
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_buf_queue (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol video_devdata
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol video_devdata (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_fop_poll
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_fop_poll (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_qbuf
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_qbuf (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_ctrl_find
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_ctrl_find (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_get_vq
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_get_vq (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol media_device_cleanup
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol media_device_cleanup (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol vb2_buffer_done
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol vb2_buffer_done (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol vb2_plane_vaddr
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol vb2_plane_vaddr (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_ctrl_subscribe_event
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_ctrl_subscribe_event (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_fh_init
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_fh_init (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_reqbufs
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_reqbufs (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol video_unregister_device
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: Unknown symbol video_unregister_device (err -22)
Jan 19 15:07:04 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_streamoff
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_streamoff (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_event_subscribe
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_event_subscribe (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_create_bufs
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_create_bufs (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_ctrl_new_std_menu
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_ctrl_new_std_menu (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_device_register
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_device_register (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_streamon
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_streamon (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_fop_mmap
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_fop_mmap (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol __video_register_device
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol __video_register_device (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol vb2_ops_wait_prepare
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol vb2_ops_wait_prepare (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_ctrl_new_std (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_ctrl_handler_free
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_ctrl_handler_free (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_device_unregister
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_device_unregister (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ctx_init
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ctx_init (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_event_queue_fh
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_event_queue_fh (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol video_device_release_empty
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol video_device_release_empty (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_register_media_controller
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_register_media_controller (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_dqbuf
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_dqbuf (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_event_unsubscribe
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_event_unsubscribe (err -22)
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: disagrees about version of symbol v4l2_m2m_ioctl_prepare_buf
Jan 19 15:07:05 raspberrypi kernel: bcm2835_codec: Unknown symbol v4l2_m2m_ioctl_prepare_buf (err -22)
Jan 19 15:07:05 raspberrypi kernel: snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
Jan 19 15:07:05 raspberrypi kernel: bcm2835_audio bcm2835_audio: card created with 8 channels
Jan 19 15:07:05 raspberrypi systemd[1]: Found device /dev/ttyAMA0.
Jan 19 15:07:07 raspberrypi systemd[1]: Found device /dev/disk/by-partuuid/9716bbe5-01.
Jan 19 15:07:08 raspberrypi mtp-probe[149]: checking bus 1, device 3: “/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.1”
Jan 19 15:07:08 raspberrypi mtp-probe[150]: checking bus 1, device 4: “/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2”
Jan 19 15:07:08 raspberrypi mtp-probe[150]: bus: 1, device: 4 was not an MTP device
Jan 19 15:07:09 raspberrypi mtp-probe[149]: bus: 1, device: 3 was not an MTP device
Jan 19 15:07:09 raspberrypi kernel: tbsusbversion 2020-10-13
Jan 19 15:07:09 raspberrypi kernel: dvb-usb: found a ‘TBS 5580 CI USB2.0’ in cold state, will try to load a firmware
Jan 19 15:07:09 raspberrypi kernel: dvb-usb: downloading firmware from file ‘dvb-usb-id5580.fw’
Jan 19 15:07:09 raspberrypi kernel: tbs5580: start downloading TBS5580 firmware
Jan 19 15:07:10 raspberrypi kernel: dvb-usb: found a ‘TBS 5580 CI USB2.0’ in warm state.
Jan 19 15:07:10 raspberrypi kernel: dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
Jan 19 15:07:10 raspberrypi kernel: dvbdev: DVB: registering new adapter (TBS 5580 CI USB2.0)
Jan 19 15:07:10 raspberrypi kernel: usb 1-1.2: USB disconnect, device number 4
Jan 19 15:07:10 raspberrypi kernel: tbs5580: read eeprom failed.
Jan 19 15:07:10 raspberrypi kernel: dvb-usb: MAC address reading failed.
Jan 19 15:07:10 raspberrypi systemd-udevd[113]: Using default interface naming scheme ‘v240’.
Jan 19 15:07:10 raspberrypi kernel: i2c i2c-11: Added multiplexed i2c bus 12
Jan 19 15:07:10 raspberrypi kernel: si2183 11-0067: Silicon Labs Si2183 successfully attached
Jan 19 15:07:10 raspberrypi systemd[1]: Starting File System Check on /dev/disk/by-partuuid/9716bbe5-01…
Jan 19 15:07:10 raspberrypi kernel: si2157 12-0061: Silicon Labs Si2147/2148/2157/2158 successfully attached
Jan 19 15:07:10 raspberrypi kernel: i2c i2c-12: av201x: Airoha Technology AV201x successfully attached
Jan 19 15:07:10 raspberrypi kernel: tbs5580: CI initialized.
Jan 19 15:07:10 raspberrypi kernel: usb 1-1.2: DVB: registering adapter 0 frontend 0 (TBS 5580 CI USB2.0 DVB-T/T2/C/C2/ISDB-T)…
Jan 19 15:07:10 raspberrypi kernel: usb 1-1.2: DVB: registering adapter 0 frontend 1 (TBS 5580 CI USB2.0 DVB-S/S2/S2X)…
Jan 19 15:07:10 raspberrypi kernel: dvb-usb: TBS 5580 CI USB2.0 successfully initialized and connected.
Jan 19 15:07:10 raspberrypi kernel: usbcore: registered new interface driver tbs5580
Jan 19 15:07:10 raspberrypi kernel: dvb-usb: TBS 5580 CI USB2.0 successfully deinitialized and disconnected.
Jan 19 15:07:12 raspberrypi kernel: usb 1-1.2: new high-speed USB device number 5 using dwc_otg
Jan 19 15:07:12 raspberrypi kernel: usb 1-1.2: New USB device found, idVendor=734c, idProduct=5580, bcdDevice= 0.01
Jan 19 15:07:12 raspberrypi kernel: usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jan 19 15:07:12 raspberrypi kernel: usb 1-1.2: Product: TBS 5580
Jan 19 15:07:12 raspberrypi kernel: usb 1-1.2: Manufacturer: TBS-Tech
Jan 19 15:07:12 raspberrypi kernel: tbsusbversion 2020-10-13
Jan 19 15:07:12 raspberrypi kernel: dvb-usb: found a ‘TBS 5580 CI USB2.0’ in cold state, will try to load a firmware
Jan 19 15:07:12 raspberrypi kernel: dvb-usb: downloading firmware from file ‘dvb-usb-id5580.fw’
Jan 19 15:07:12 raspberrypi kernel: tbs5580: start downloading TBS5580 firmware
Jan 19 15:07:12 raspberrypi systemd[1]: Condition check resulted in FUSE Control File System being skipped.
Jan 19 15:07:12 raspberrypi systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch being skipped.
Jan 19 15:07:12 raspberrypi systemd[1]: Condition check resulted in Huge Pages File System being skipped.
Jan 19 15:07:12 raspberrypi systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jan 19 15:07:12 raspberrypi systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
Jan 19 15:07:12 raspberrypi kernel: dvb-usb: found a ‘TBS 5580 CI USB2.0’ in warm state.
Jan 19 15:07:12 raspberrypi kernel: dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
Jan 19 15:07:12 raspberrypi kernel: dvbdev: DVB: registering new adapter (TBS 5580 CI USB2.0)
Jan 19 15:07:12 raspberrypi kernel: dvb-usb: MAC address: 00:22:ab:c0:56:4d
Jan 19 15:07:12 raspberrypi systemd-fsck[155]: fsck.fat 4.1 (2017-01-24)
Jan 19 15:07:12 raspberrypi systemd-fsck[155]: /dev/mmcblk0p1: 251 files, 110096/516190 clusters
Jan 19 15:07:12 raspberrypi systemd[1]: Started File System Check on /dev/disk/by-partuuid/9716bbe5-01.
Jan 19 15:07:12 raspberrypi kernel: i2c i2c-11: Added multiplexed i2c bus 12
Jan 19 15:07:12 raspberrypi kernel: si2183 11-0067: Silicon Labs Si2183 successfully attached
Jan 19 15:07:12 raspberrypi systemd[1]: Mounting /boot…
Jan 19 15:07:12 raspberrypi kernel: si2157 12-0061: Silicon Labs Si2147/2148/2157/2158 successfully attached
Jan 19 15:07:12 raspberrypi kernel: i2c i2c-12: av201x: Airoha Technology AV201x successfully attached
Jan 19 15:07:12 raspberrypi kernel: tbs5580: CI initialized.
Jan 19 15:07:12 raspberrypi kernel: tbs5580: CI disabled.
Jan 19 15:07:12 raspberrypi kernel: usb 1-1.2: DVB: registering adapter 0 frontend 0 (TBS 5580 CI USB2.0 DVB-T/T2/C/C2/ISDB-T)…
Jan 19 15:07:12 raspberrypi kernel: usb 1-1.2: DVB: registering adapter 0 frontend 1 (TBS 5580 CI USB2.0 DVB-S/S2/S2X)…
Jan 19 15:07:12 raspberrypi kernel: dvb-usb: TBS 5580 CI USB2.0 successfully initialized and connected.
Jan 19 15:07:13 raspberrypi systemd[1]: Mounted /boot.
Jan 19 15:07:13 raspberrypi systemd[1]: Reached target Local File Systems.
Jan 19 15:07:13 raspberrypi systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jan 19 15:07:13 raspberrypi systemd[1]: Starting Set console font and keymap…
Jan 19 15:07:13 raspberrypi systemd[1]: Starting Create Volatile Files and Directories…
Jan 19 15:07:13 raspberrypi systemd[1]: Starting Raise network interfaces…
Jan 19 15:07:13 raspberrypi systemd[1]: Starting Preprocess NFS configuration…
Jan 19 15:07:13 raspberrypi systemd[1]: Starting Tell Plymouth To Write Out Runtime Data…
Jan 19 15:07:13 raspberrypi systemd[1]: Started Set console font and keymap.
Jan 19 15:07:13 raspberrypi systemd[1]: nfs-config.service: Succeeded.
Jan 19 15:07:13 raspberrypi systemd[1]: Started Preprocess NFS configuration.
Jan 19 15:07:13 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS client and server being skipped.
Jan 19 15:07:13 raspberrypi systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
Jan 19 15:07:13 raspberrypi systemd[1]: Reached target NFS client services.
Jan 19 15:07:13 raspberrypi systemd[1]: Reached target Remote File Systems (Pre).
Jan 19 15:07:13 raspberrypi systemd[1]: Reached target Remote File Systems.
Jan 19 15:07:14 raspberrypi systemd[1]: Started Create Volatile Files and Directories.
Jan 19 15:07:14 raspberrypi systemd[1]: Starting Update UTMP about System Boot/Shutdown…
Jan 19 15:07:14 raspberrypi systemd[1]: Starting Network Time Synchronization…
Jan 19 15:07:15 raspberrypi systemd[1]: Received SIGRTMIN+20 from PID 114 (plymouthd).
Jan 19 15:07:15 raspberrypi systemd[1]: plymouth-read-write.service: Succeeded.
Jan 19 15:07:15 raspberrypi systemd[1]: Started Tell Plymouth To Write Out Runtime Data.
Jan 19 15:07:15 raspberrypi systemd[1]: Started Update UTMP about System Boot/Shutdown.
Jan 19 15:07:17 raspberrypi systemd[1]: Started Raise network interfaces.
Jan 19 15:07:17 raspberrypi mtp-probe[235]: checking bus 1, device 5: “/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.2”
Jan 19 15:07:17 raspberrypi mtp-probe[235]: bus: 1, device: 5 was not an MTP device
Jan 19 15:07:17 raspberrypi systemd[1]: Started Network Time Synchronization.
Jan 19 15:07:17 raspberrypi systemd[1]: Reached target System Time Synchronized.
Jan 19 15:07:17 raspberrypi systemd[1]: Reached target System Initialization.
Jan 19 15:07:17 raspberrypi systemd[1]: Started CUPS Scheduler.
Jan 19 15:07:17 raspberrypi systemd[1]: Reached target Paths.
Jan 19 15:07:17 raspberrypi systemd[1]: Listening on CUPS Scheduler.
Jan 19 15:07:17 raspberrypi systemd[1]: Listening on triggerhappy.socket.
Jan 19 15:07:17 raspberrypi systemd[1]: Started Daily apt download activities.
Jan 19 15:07:17 raspberrypi systemd[1]: Listening on D-Bus System Message Bus Socket.
Jan 19 15:07:17 raspberrypi systemd[1]: Started Daily apt upgrade and clean activities.
Jan 19 15:07:17 raspberrypi systemd[1]: Started Daily man-db regeneration.
Jan 19 15:07:17 raspberrypi systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
Jan 19 15:07:17 raspberrypi systemd[1]: Reached target Sockets.
Jan 19 15:07:17 raspberrypi systemd[1]: Reached target Basic System.
Jan 19 15:07:17 raspberrypi systemd[1]: Condition check resulted in Turn on SSH if /boot/ssh is present being skipped.
Jan 19 15:07:17 raspberrypi systemd[1]: Starting Disk Manager…
Jan 19 15:07:18 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)…
lines 523-626
NOTE: this is only a small part of journal log. Unfortunately, I do not know which part is interesting for you and I’m not allowed to upload more lines or full txt file.
TVheadend client running on Vero4k, logs:
https://paste.osmc.tv/esicakerej
FWIW:
When disconnecting ETH, OSMC on Vero4k runs stable. Also, when disabling TVheadend client on Vero4k OSMC runs stable. So it’s definitely related to TVheadend.
I assume it’s related to the client, not the server, since I’m still able to access TVheadend server from other devices in my network.
There is clearly an issue between the TVH Client and Server
ERROR: GetChannels: Add-on 'Tvheadend:192.168.178.25:9982' returned an error: the command failed
While I don’t think that has any impact I wonder as yu currently not using the TVHeadend Server on the Vero maybe you want to remove that to exclude it as a source of any issues.
Thanks!
Here’s the link: https://paste.osmc.tv/openaduseh.md
FYI: RPI TVH Server IP 192.168.178.25
Vero4k TVH Client IP 192.168.178.34
So I’m not sure what you mean by “removing that to exclude it as source of issues”, since I do want to get channesl from address 192.168.178.25:9982, don’ I?
I was refering to the TVHeadend Server that you installed on the Vero (via MyOSMC App Store). That is currently not needed while you use the Vero as Client only.
Ah, got it, you’re right of course. I’ve disabled it now.
Anyhting else you can tell from the logs?
Other than that “command failed” entry not really. I think you would need to check the TVHeadend logs on the server to maybe see more details.
Are you confident that the network between the two devices is stable? Maybe do a iperf3 test for a couple of minutes.
I can see that Kodi crashed because of a thread-related problem:
Jan 23 09:28:31 VERO4K mediacenter[2398]: kodi.bin: pthread_mutex_lock.c:430: __pthread_mutex_lock_full: Assertion `INTERNAL_SYSCALL_ERRNO (e, __err) != EDEADLK || (kind != PTHREAD_MUTEX_ERRORCHECK_NP && kind != PTHREAD_MUTEX_RECURSIVE_NP)' failed.
Jan 23 09:28:31 VERO4K kernel: fb: osd_release now.index=0,open_count=1
Jan 23 09:28:31 VERO4K sudo[4213]: pam_unix(sudo:session): session closed for user osmc
Jan 23 09:28:31 VERO4K mediacenter[2398]: /usr/bin/mediacenter: line 212: 4213 Aborted sudo -u osmc MALLOC_MMAP_THRESHOLD_=8192 LIRC_SOCKET_PATH=/var/run/lirc/lircd $KODI --standalone -fs
Jan 23 09:28:31 VERO4K mediacenter[2398]: Kodi exited with return code 134 after 0 hours, 0 minutes and 18 seconds
Unfortunately, the OSMC log starts at around 09:20 on 23 Jan but the RaspiOS journal only goes as far as Jan 19 18:10, so it’s not possible to correlate events between the logs.
I noticed that to, but 19.01. was the latest date in the journal logs I could find.
Quick test:
sudo journalctl | tail
Quick test:
pi@raspberrypi:~ $ sudo journalctl | tail
Jan 23 19:23:55 raspberrypi rngd[268]: stats: FIPS tests speed: (min=547.769; av g=3950.496; max=6333.090)Kibits/s
Jan 23 19:23:55 raspberrypi rngd[268]: stats: Lowest ready-buffers level: 2
Jan 23 19:23:55 raspberrypi rngd[268]: stats: Entropy starvations: 0
Jan 23 19:23:55 raspberrypi rngd[268]: stats: Time spent starving for entropy: ( min=0; avg=0.000; max=0)us
Jan 23 19:45:34 raspberrypi sshd[1194]: Accepted password for pi from 192.168.17 8.36 port 51307 ssh2
Jan 23 19:45:34 raspberrypi sshd[1194]: pam_unix(sshd:session): session opened f or user pi by (uid=0)
Jan 23 19:45:34 raspberrypi systemd-logind[238]: New session 14 of user pi.
Jan 23 19:45:34 raspberrypi systemd[1]: Started Session 14 of user pi.
Jan 23 19:45:41 raspberrypi sudo[1215]: pi : TTY=pts/0 ; PWD=/home/pi ; US ER=root ; COMMAND=/usr/bin/journalctl
Jan 23 19:45:41 raspberrypi sudo[1215]: pam_unix(sudo:session): session opened f or user root by pi(uid=0)
There’s a 10MB limit on posting files, so to see if you’re below this limit run:
sudo journalctl | wc -c
If it’s below 10MB, run
sudo journalctl | curl -X POST -T - https://paste.osmc.tv/documents
and post the 10-character key it returns.
Not sure if it’s bytes or kB:
pi@raspberrypi:~ $ sudo journalctl | wc -c
675898
Anyway, seems to be <10MB, since upload worked:
pi@raspberrypi:~ $ sudo journalctl | curl -X POST -T - https://paste.osmc.tv/documents
{“key”:“oyesigirak”}pi@raspberrypi:~ $
It’s bytes. The -c
part means characters.
You were running the stock 3.14 kernel on your V4K+ but moved to the beta 4.9 kernel due to module build issues. Are you still on 4.9?
You say that you’ve now disabled the TVH server on the V4K+, which was accidentally left running. Have the problems persisted since then?
Finally, I see that the TVH server is now on a Pi 1. The latest RaspiOS log is full of subscribing / time-out / unsubscribing messages, eg:
Jan 23 09:27:45 raspberrypi tvheadend[445]: subscription: 0001: "epggrab" subscribing...
Jan 23 09:27:46 raspberrypi tvheadend[445]: linuxdvb: TBS 5580 CI USB2.0 DVB-S/S2/S2X #0 : DVB-S #1 - poll TIMEOUT
Jan 23 09:27:46 raspberrypi tvheadend[445]: linuxdvb: TBS 5580 CI USB2.0 DVB-S/S2/S2X #0 : DVB-S #1 - retune nodata
Jan 23 09:28:25 raspberrypi tvheadend[445]: subscription: 0001: "epggrab" unsubscribing
I don’t run TVH myself, but this doesn’t look encouraging. Perhaps someone more knowledgeable can comment.
For reference, here’s the RaspiOS log https://paste.osmc.tv/oyesigirak
Sorry for late response.
After turning off TVH Server on Vero4k, it doesn’t crash anymore, although I’m not sure this is related. I still get subscribing/time-out error logs on RPI TVH server side. I guess for that reason I can’t successfully stream anything from RPI TVH server from any client.
Anyway, I got an RPI4, which I’ll be setting up the next days. Maybe all issues will be gone by then.
EDIT:
The subscribing/time-out errors might have been related to CI-Module I’ve inserted into DVB-Tuner CI-slot. After I’ve enabled this slot in TVH server settings, the subscribing/time-out errors were gone.
