reproduce the issue
Before unplugging the drive did you either, power off the device, go to videos>files> highlight “Elements” then context menu>safely remove, or via ssh umount /media/Elements? If you restart the device is it still mounted as read only?
If I’m reading it correctly the system is telling it to mount as read/write but the drive is set as read only. Can you write to it when it it plugged into a PC? Searching the internet finds that as external WD drive getting set as read only out of the blue isn’t an unheard of problem. If this is what is going on then you could try [this].
IIRC, I had to change a setting in Windows 11 that was making the drive work like a system drive, not a USB device. The Safely remove hardware option wasn’t available previously, so when it was time to disconnect the device, I just unplugged it. Maybe I should have unplugged the USB before power. Anyway, Safely remove hardware is now available, and I connected the drive to Win 11 PC again, used the manufacturer’s tool to run a full scan (which took a whole day) and ejected the device safely. I connected it to OSMC again, and have not had the issue since.
Happy to report issue resolved.
(HDDs are both self-powered. HDDs and gamepad all three use the USB ports on device, Raspberry pi 3 v2.)
