will it be please possible to add HID_BETOP_FF as a kernel module? (option CONFIG_HID_BETOP_FF=m)
It is used by some cheap wireless gamepads that can be then used in RetroPie/Retrosmc.
I’ve just compiled the kernel with this option enabled using your advice at Compile Kernel on RPI2 from RBP2-sources-osmc - #2 by DBMandrake (thank you!) to make the gamepad work, but it takes quite a lot of time to compile and I suppose that the next kernel update will roll it back.
Thank you and thank you very much for the great work you are doing!
