Hi, I just ordered a Vero 4K+ and want to hook up 2.5" USB drives to it. I have a Wavlink USB 7 Port Powered Hub and wanted to know if this will be sufficient and compatible with the Vero 4K+.
Anyone else have this model ?
Wavlink USB 7 Port Powered Hub UH3076
Any powered hub with USB-A should work fine. I don’t see why your Wavlink would be an issue.
yeah Ill try it out once I receive the Vero
I have the same usb hub like you just the smaller port with 4usb ports and it works flawlessly with my vero.
Ok great thanks for that
Received the Vero today and yes my USB hub works with it
