I just started playing with RC OSMC but running in to issues trying to get lirc set up. I can get my MCE remote to work but trying to get my amp remote working which I had set up on my old xbmc setup by programming as a samsung remote and using required remote files and mappings but just not sure where all the necessary files need to go. anyone got any tips?
Ta
Stu
ok so I got this to work by looking around some other threads that have come up in the last few days
Raspberry Pi LIRC instructions
set onkyo remote to MCE remote code using code 30522 (hold game/other and display and then enter code)
I used the following instructions to record the ones i needed so if you have different remote then you can try and record your own but the keynames should help you.
sudo systemctl stop lircd_helper@lirc0
Once that is stopped you can use irrecord - but you must specify the correct device node as the default is incorrect:
irrecord -d /dev/lirc0 /home/osmc/lircd.conf
Once you’re finished you can start lircd again:
sudo systemctl start lircd_helper@lirc0
this is the lircd.conf file
# Bear in mind this has only been tested with the ONKYO remote set to a microsoft remote using the code above
# Please make this file available to others
# by sending it to <lirc@bartelmus.de>
# this config file was automatically generated
# using lirc-0.9.0(default) on Tue Mar 24 17:34:52 2015
# contributed by
# brand: /home/osmc/lircd.conf
# model no. of remote control:
# devices being controlled by this remote:
begin remote
name /home/osmc/lircd.conf
bits 13
flags RC6|CONST_LENGTH
eps 30
aeps 100
header 2652 844
one 451 430
zero 451 430
pre_data_bits 24
pre_data 0x1BFF80
gap 106084
toggle_bit_mask 0x8000
rc6_mask 0x100000000
begin codes
KEY_1 0x0BFE
KEY_2 0x0BFD
KEY_3 0x0BFC
KEY_4 0x0BFB
KEY_5 0x0BFA
KEY_6 0x0BF9
KEY_7 0x0BFB
KEY_8 0x0BF7
KEY_9 0x0BF6
KEY_0 0x0BFF
KEY_EXIT 0x0BDC
KEY_UP 0x0BE1
KEY_DOWN 0x0BE0
KEY_LEFT 0x0BDF
KEY_RIGHT 0x0BDE
KEY_PLAYPAUSE 0x0BE9
KEY_STOP 0x0BE6
KEY_PAUSE 0x0BE7
KEY_FASTFORWARD 0x0BEB
KEY_REWIND 0x0BEA
KEY_NEXTSONG 0x0BE5
KEY_PREVIOUSSONG 0x0BE4
KEY_INFO 0x0BAE
KEY_OPTION 0x0BDB
KEY_OK 0x0BF4
KEY_CONTEXT_MENU 0x0BDB
end codes
end remote
