I have Openelec (6.0.1) on my ATV1 with broadcom card. Running Kodi 15.2 …v old now…It’s OK…but just wanted to try out Sams version…just can’t seem to load from USB to try it out. I have a 8g Cruzer slice and have formatted it but to no joy.
Thanks Sam…I have tried 3 different USB sticks now…all different and it hangs halfway through during the install bit…I have Openelec which runs OK …ish…will be getting a Vero 4k soon, but just wanted to check out the OS before I make the plunge…and at the moment I can’t get my feet wet!
I’m afraid OSMC on AppleTV won’t be a very good testament as to OSMC on Vero 4K. There’s quite a difference as the AppleTV is just over ten years old now.
Thanks again for the quick reply. I guess I won’t see much difference anyway if I get it working as we know the ATV1 is 10 years old. I was just curious really as I only have kodi 15.2 running and quite a few addons require updating and can not. I really need a new box…love the super connectivity of the Vero4k just wanted to give it a test run first.
In the meantime I will try another build like the 1.1.17 USB from the disk image.
