Hi guys , i installed homebridge on the vero4k+ so i can control smart things that are not officially homekit supported to work with homekit on my iPhone ( eg my smart lights and alarm system )
But to control it outside the local network of the vero , i also need a homekit hub .
That hub i made of an old iPhone 8 that is jailbroken so i could enable home hub for the iPhone that otherwise is only available on an iPad or HomePod.
So far so good, everything is working perfectly .
but the iPhone needs to be on all the time
Is it a problem that i connect it 24-7 to the usb port of the vero or isn’t that a good idea ?? if yes is there a usb port u recommend ?
thanks Tom
