USB Power
Is there a way ot turn of power to the attached USB HDD when the Vero is in suspend mode, could not see any under power saving mode.
Drives will be automatically put in to standby after 15 minutes of inactivity
Is the drive powered via USB? You are asking for trouble if so.
Thanks for the replies. I have 3 HDDS attached via the Vero powered USB hub and all is well. To be a bit greener I power the USB hub down when not in use, the HDDs then draw power from the Vero when it is standby. Is there a way to change the 15 minutes ?
This will cause serious problems. I don’t recommend doing this.
15 minutes is the minimum standby time currently.
Thanks for the advice, I have reverted to leaving the USB hub on
