Hi all! I’m new to this! Appreciate your help! (checked related USB threads but no answer)
Background
- Installed OSMC on USB stick by selecting install from SD (win 7)
- Plug USB stick into Pi2 (micro SD inside already).
Nothing happened even after restart.
How should i go about this? Thanks!
You need to write the installer to the sd card even if doing a usb instal
HI
I think you’ve got it wrong. A SD card is still needed to boot.
I’ve got two berries, booth are running OSMC on a USB stick.
Here is a how-to video over at youtube Raspbmc - USB INSTALL - TUTORIAL - (HD) - YouTube
And for a good read, I can recommend http://mymediaexperience.com/raspberry-pi-xbmc-with-raspbmc/
Also uses some nice screen shots of OSMC.
Or take a look here. Wiki - OSMC
