I have USB wifi device with RTL8812AU chipset. This was working fine in OSMC running on Rpi3, but stopped working after 2019.11 update. I installed OSMC from scratch. Still the device is not working. Combed through the forums. Most of posts say driver is included. But not sure why its not working. I have tested the device on other linux and windows machines, it works fine.
Below is the lsusb output:
osmc@osmc:~$ lsusb
Bus 001 Device 005: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
Bus 001 Device 006: ID 0bda:8812 Realtek Semiconductor Corp. RTL8812AU 802.11a/b/g/n/ac 2T2R DB WLAN Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
modify to enable RPI build as instructed in README
initiate build using make
make will fail with below error
osmc@osmc:~/rtl8812au$ make
make ARCH=arm CROSS_COMPILE= -C /lib/modules/4.19.55-6-osmc/build M=/home/osmc/rtl8812au modules
make[1]: Entering directory '/usr/src/rbp2-headers-4.19.55-6-osmc'
CC [M] /home/osmc/rtl8812au/core/rtw_cmd.o
In file included from ./include/linux/compat.h:16:0,
from ./include/linux/ethtool.h:17,
from ./include/linux/netdevice.h:41,
from /home/osmc/rtl8812au/include/osdep_service_linux.h:35,
from /home/osmc/rtl8812au/include/osdep_service.h:41,
from /home/osmc/rtl8812au/include/drv_types.h:32,
from /home/osmc/rtl8812au/core/rtw_cmd.c:22:
./include/linux/if.h:28:54: fatal error: sys/socket.h: No such file or directory
#include <sys/socket.h> /* for struct sockaddr. */
compilation terminated.
