I’m trying to put my RPi 2, which is running the latest OSMC build, through a Sony AV receiver but I’m not able to get it to work.
I’ve tried all HDMIs/channels which normally run a satellite box, PS4 etc but I’m having no luck.
Are there any settings I need to enable to get it to work, potentially in Config.txt? I’ve been doing some research but I can’t get a definitive answer and don’t want to configure it incorrectly.
A low risk experiment would be to try setting hdmi_boost in config.txt
So far I have only had to do this in one situation … when going through a HDMI-to-VGA converter.
In that case I set it to 6 I think.
Thanks both. I’ll try get the HDMI out cable from the receiver so I can go straight to the TV as it’s not connected to the WiFi yet. Will report back when I’ve attempted both.
