I have an Apple mini BT keyboard which I use with my iMac.
Is it possible to have it paired with the Vero instead ? How so ?
TIA
TIA
That should work. First make sure you have installed the latest OSMC updates.
Then go into the Networking section of OSMC settings and you should see a Bluetooth section. Enable this and put your keyboard into pairing mode. After a few seconds you should see your keyboard in the right hand list - select this option then enter the pairing code (followed by enter) on the keyboard when prompted.
It should then appear in green on the left hand side and after a number of seconds the keyboard should be working.
