Thanks But this doesn’t tell me how to recreate a deleted symlink. In fact I could find out how to create a symlink but I don’t even know what file to link?
The command you use is ln -s, and you can consult man pages for usage details.
I suspect that you need to link your lircd.conf to /etc/lircd.conf - but this is merely an informed guess.
Derek
I think you’ll need o supply more info.
As a start, is /etc/lirc/lircd shown as linked to your newly generated lircd conf file? ( use ls -l /etc/lirc/lircd to show it).
And what Lircmap.xml are you using - does it have the same button names?
Derek
The only thing I can spot which might be slightly wrong is that in the lircmap you have the device name as my-remote, whereas in the lircd.conf you have my-remote.lircd. This doesn’t seem to accord, to me.
Apart from that you’ve duplicated my attempts, and also got to failure.
I’ve tried turning on debugging and watching the log, and find oddities which suggest that either the system is appropriating certain keystrokes or the mapping isn’t working the way documentation says.
Perhaps @DBMandrake might have a suggestion.
Derek
I really hope I can make this thing work 'cause I have domotic in my house and it makes it really easy to use the universal remote… Plus it used to work with OpenElec.
But thanks for your help. I may try it all over again.
You’re experiencing the RC6 “toggle bit” where every other key press repeats and you recorded one of the two toggles. Best to use one of the included files for RC6 and modify it to suit your needs.
