V Tuner an Raspberry Pi
Another thing i own a Harman AVR 320 with virtual tuner, called vtuner, but like most other manufactors Harman stopped the Vtuner support. But there is an alternative Project call Ytuner, that you can run on your PC, my quedtion is, would it be possible to run Ytuner on a raspberry Pi 3b wirh osmc ?
My Pi media center is running 24/7 an is consuming not much energy.
Well you could have saved people time if you directly would have linked to the project.
And the page says:
“of ultra lightweight native app on operating systems such as: Linux, macOS, BSD, Solaris, Raspberry Pi OS, OpenWRT, Windows”
So the initial answer is yes it should be possible to run on OSMC.
guys , I wrote a simple piece of code that you can solve with esp8266 so you can connect to vtuner.
https://github.com/AnnenMayKante/Pioneer-vTuner-Fix-ESP8266
