Well personally I am always suggesting to use Kernel Based mounts (e.g. autofs).
But for Kodi to add shares check this post
Î found out why my remote is not working on v19.
The second USB Port (if you counting from the front) is dead/not working.
I tried to insert a USB Drive and it didn’t got detected.
On v18 both Ports are working
Interesting find, let us check if we can replicate
For now i fixed almost everything except:
Framerates and “not working” USB Port.
Did you successfully replicate my error?
Will investigate the USB port issue.
Do you know when you purchased your device?
On the 20.01.2020
Edit:
Fixed Framerates working, so it’s only the USB Port left ))
Not sure if it’s the same issue as the jittering but since 19.1 on my Vero 4k+ my subtitles and UI during playback are having tearing issues, much like games without V-Sync. So going back into the menu during playback will have very bad tearing, like half the menu being a few milliseconds late when changing between screens. Subtitles changing between lines will appear partially first before the rest comes too.
My player is set to adjust refresh rate so that would be 24p or 60p in these cases, happens both times. If this were a videogame I’d look for the “V-Sync on” function.
Also experiencing short green distortions in the lower part of the frame when seeking in a video. Might be related since they change in size and position too.
@irockintomordor
Did you check your video Settings?
OSMC defaulted my Video Settings to 1080i instead of 1080p.
This will cause all kind of “V-Sync off” Jitter.
Also a fresh Install could help.
@sam_nazarko
Any news?
One working USB Port is kind of a Dealbreaker for me, cause I’m using it for the Remote.
@Alyx
thanks for the suggestion! It’s one of the first things I suspected but it’s 1080p60 as usual. I’ve played around with settings but couldn’t solve the tearing. Fresh install - maybe when I find the time. I’ll monitor the issue here and on my device.
Still investigating – will get it fixed, don’t worry.
wanted to report, that i checked the power output of the usb port and it does charge my controller.
It just doesn’t recognize any peripheral devices.
I first assumed there was no power because my usb stick didn’t lit up
Maybe this can help you:
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 2017:1688
usb-devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev=04.09
S: Manufacturer=Linux 4.9.113-45-osmc xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=xhci-hcd.0.auto
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#=0x0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=1.5 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=2017 ProdID=1688 Rev=01.04
S: Manufacturer=OSMC Remote Controller
S: Product=USB Keyboard Mouse
C: #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=100mA
I: If#=0x0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
I: If#=0x1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=01 Driver=usbhid
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 0
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev=04.09
I: If#=0x0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=(none)
Any Progress?
The 19.3 November Update didn’t solve the Problem.
Just to clarify – your issue is that the remote only works on one port?
yes and it’s not only the remote, any device e.g a usb flash drive only works on one port.
The second port just charges.
Problem occured since v19, if i downgrade to v18 everything works.
From my understanding it seems like BUS02 (USB Ver 3.0) is not working
We don’t have a USB3 PHY on Vero 4K + – so that message can be safely ignored.
I’ll continue to investigate the matter
This should now be fixed.
- Login via the command line
- Run the following command to add the staging repository:
echo 'deb http://apt.osmc.tv buster-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
- Run the following commands to update:
- Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list
after updating.
I’d also recommend you deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list
Thanks for your patience
I’ll test it tomorrow after work and give you a feedback.
Thanks for your hard work!!
