After Upgrading my Vero4k+ to 19.1 I got a few issues:
My Original OSMC Remote stopped working.
Repairing (Home Button + OK Button till flashing) and reconnect the Dongle, didn’t solve my issue. -
My UI is very slow , unresponsive and jitter like while Video Playback.
If I quit the Video , the UI than works as expected.
Tested it with Add-ons and Local Stored Videos.
The FPS drops to 7.5 in the UI while Video Playback.
This should be the issue here.
3.Normally I would get 23.976 FPS in my Movies/Animes.
Now it jumping between 8-30 FPS.
So no fixed Framerate
I thought maybe I should try a clean install.
Log file: https://paste.osmc.tv/xodejiwewi
Anime (should be with a fixed Framerate (23.976) instead getting 30 fps):
General
Unique ID : 141840380726005818817032598510659038805 (0x6AB576B22EBC274A7E084F7BDE6DEE55)
Complete name : Z:\Anime\Gintama S 1-10\Season 5\Gintama - S05E15 - I Can't Remember a Damn Thing About the Factory Tour.mkv
Format : Matroska
Format version : Version 4
File size : 208 MiB
Duration : 24 min 1 s
Overall bit rate : 1 214 kb/s
Encoded date : UTC 2020-04-04 16:17:56
Writing application : mkvmerge v45.0.0 ('Heaven in Pennies') 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2 / Lavf58.29.100
Video
Format : HEVC
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 1 107 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.022
Stream size : 190 MiB (91%)
Title : [Judas] x265 10b
Writing library : x265 3.3+2-gbe2d82093:[Windows][GCC 9.2.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=5 / numa-pools=20,20 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=6 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=100 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=3 / tu-intra-depth=3 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=4 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / weightb / no-analyze-src-pics / deblock=-1:-1 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=0.80 / psy-rdoq=1.30 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=22.0 / qcomp=0.68 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=0.90 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0
Language : Japanese
Default : Yes
Forced : No
Audio
Format : Opus
Codec ID : A_OPUS
Bit rate : 104 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 50.000 FPS (960 SPF)
Compression mode : Lossy
Stream size : 17.9 MiB (9%)
Title : [Judas] JAP Stereo (Opus 112Kbps)
Writing library : Lavc58.54.100 libopus
Language : Japanese
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Duration : 22 min 5 s
Bit rate : 183 b/s
Count of elements : 535
Compression mode : Lossless
Stream size : 29.7 KiB (0%)
Title : English
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : :Chapter 01
00:01:31.007 : :Chapter 02
00:01:41.017 : :Chapter 03
00:12:32.001 : :Chapter 04
00:22:09.995 : :Chapter 05
00:23:40.001 : :Chapter 06
Movie:
General
Unique ID : 70435950895531548702109589481248098684 (0x34FD787FBCA0C3C1887BCCBE92A1897C)
Complete name : Z:\Movies\The Gentlemen (2019).mkv
Format : Matroska
File size : 30.1 GiB
Duration : 1 h 54 min
Overall bit rate : 37.8 Mb/s
Encoded date : UTC 2020-07-09 09:46:21
Writing application : mkvmerge v31.0.0 ('Dolores In A Shoestand') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
Video
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Bit rate : 28.7 Mb/s
Width : 3 840 pixels
Height : 1 608 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.194
Stream size : 22.9 GiB (76%)
Writing library : x265 3.4+11-gee5a266a1:[Windows][MSVC 1900][64 bit] 10bit
Encoding settings : cpuid=1049583 / frame-threads=5 / numa-pools=32 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x1608 / interlace=0 / total-frames=164345 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / repeat-headers / annexb / aud / hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=13.5 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=1 / chromaloc-top=2 / chromaloc-bottom=2 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50) / cll=932,813 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 932 cd/m2
Maximum Frame-Average Light : 813 cd/m2
Audio #1
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 4 522 kb/s
Channel(s) : 8 channels
Channel layout : C L R LFE Lb Rb Lss Rss
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Stream size : 3.61 GiB (12%)
Title : Surround 7.1
Language : German
Default : Yes
Forced : No
Audio #2
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 4 537 kb/s
Bit depth : 24 bits
Stream size : 3.62 GiB (12%)
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 1 h 39 min
Bit rate : 0 b/s
Count of elements : 12
Stream size : 310 Bytes (0%)
Title : forced srt
Language : German
Default : Yes
Forced : Yes
Text #2
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 252 b/s
Count of elements : 24
Stream size : 183 KiB (0%)
Title : forced
Language : German
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Duration : 1 h 52 min
Bit rate : 36.6 kb/s
Count of elements : 3724
Stream size : 29.5 MiB (0%)
Language : German
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:12:20.573 : en:Chapter 02
00:24:48.612 : en:Chapter 03
00:35:51.190 : en:Chapter 04
00:47:05.739 : en:Chapter 05
00:58:59.327 : en:Chapter 06
01:08:43.661 : en:Chapter 07
01:19:21.673 : en:Chapter 08
01:29:23.441 : en:Chapter 09
01:40:09.795 : en:Chapter 10
Hope CEC is working?
