running strace valgrind ./a.out gives
execve("/usr/bin/valgrind", [“valgrind”, “./a.out”], 0x7ebc1594 /* 32 vars /) = 0
brk(NULL) = 0xc82000
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f79000
access("/etc/ld.so.preload", R_OK) = 0
openat(AT_FDCWD, “/etc/ld.so.preload”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=22, …}) = 0
mmap2(NULL, 22, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0x76f78000
close(3) = 0
openat(AT_FDCWD, “/usr/lib/libarmmem.so”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0P\3\0\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=15640, …}) = 0
mmap2(NULL, 77868, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76f3f000
mprotect(0x76f42000, 61440, PROT_NONE) = 0
mmap2(0x76f51000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x76f51000
close(3) = 0
munmap(0x76f78000, 22) = 0
openat(AT_FDCWD, “/etc/ld.so.cache”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=49488, …}) = 0
mmap2(NULL, 49488, PROT_READ, MAP_PRIVATE, 3, 0) = 0x76f6c000
close(3) = 0
openat(AT_FDCWD, “/lib/arm-linux-gnueabihf/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = 3
read(3, “\177ELF\1\1\1\3\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\09v\1\0004\0\0\0”…, 512) = 512
fstat64(3, {st_mode=S_IFREG|0755, st_size=952028, …}) = 0
mmap2(NULL, 1020732, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76e45000
mprotect(0x76f29000, 65536, PROT_NONE) = 0
mmap2(0x76f39000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe4000) = 0x76f39000
mmap2(0x76f3c000, 9020, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x76f3c000
close(3) = 0
set_tls(0x76f7a100) = 0
mprotect(0x76f39000, 8192, PROT_READ) = 0
mprotect(0x76f51000, 4096, PROT_READ) = 0
mprotect(0x501000, 4096, PROT_READ) = 0
mprotect(0x76f7b000, 4096, PROT_READ) = 0
munmap(0x76f6c000, 49488) = 0
getuid32() = 1000
getgid32() = 1000
getpid() = 24413
rt_sigaction(SIGCHLD, {sa_handler=0x4ec549, sa_mask=~[RTMIN RT_1], sa_flags=SA_RESTORER, sa_restorer=0x76e6aca1}, NULL, 8) = 0
geteuid32() = 1000
brk(0xca3000) = 0xca3000
getppid() = 24409
stat64("/HDD/projects/HelloWorld", {st_mode=S_IFDIR|S_ISGID|0755, st_size=4096, …}) = 0
stat64(".", {st_mode=S_IFDIR|S_ISGID|0755, st_size=4096, …}) = 0
openat(AT_FDCWD, “/usr/bin/valgrind”, O_RDONLY|O_LARGEFILE) = 3
fcntl64(3, F_DUPFD, 10) = 10
close(3) = 0
fcntl64(10, F_SETFD, FD_CLOEXEC) = 0
geteuid32() = 1000
getegid32() = 1000
rt_sigaction(SIGINT, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGINT, {sa_handler=0x4ec549, sa_mask=~[RTMIN RT_1], sa_flags=SA_RESTORER, sa_restorer=0x76e6aca1}, NULL, 8) = 0
rt_sigaction(SIGQUIT, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGQUIT, {sa_handler=SIG_DFL, sa_mask=~[RTMIN RT_1], sa_flags=SA_RESTORER, sa_restorer=0x76e6aca1}, NULL, 8) = 0
rt_sigaction(SIGTERM, NULL, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
rt_sigaction(SIGTERM, {sa_handler=SIG_DFL, sa_mask=~[RTMIN RT_1], sa_flags=SA_RESTORER, sa_restorer=0x76e6aca1}, NULL, 8) = 0
read(10, “#!/bin/sh -e\n#\n# Valgrind wrappe”…, 8192) = 528
execve("/usr/bin/valgrind.bin", ["/usr/bin/valgrind.bin", “./a.out”], 0x504638 / 35 vars /) = 0
brk(NULL) = 0x1530000
mmap2(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x76f4c000
mmap2(NULL, 22, PROT_READ|PROT_WRITE, MAP_PRIVATE, 3, 0) = 0x76f4b000
close(3) = 0
mmap2(NULL, 77868, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76f12000
mprotect(0x76f15000, 61440, PROT_NONE) = 0
mmap2(0x76f24000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x76f24000
close(3) = 0
munmap(0x76f4b000, 22) = 0
openat(AT_FDCWD, “/usr/lib/debug/tls/v7l/neon/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls/v7l/neon/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/tls/v7l/neon/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls/v7l/neon", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/tls/v7l/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls/v7l/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/tls/v7l/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls/v7l", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/tls/neon/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls/neon/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/tls/neon/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls/neon", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/tls/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/tls/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/tls", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/v7l/neon/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/v7l/neon/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/v7l/neon/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/v7l/neon", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/v7l/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/v7l/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/v7l/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/v7l", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/neon/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/neon/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/neon/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/neon", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/vfp/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug/vfp", 0x7e984940) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, “/usr/lib/debug/libc.so.6”, O_RDONLY|O_LARGEFILE|O_CLOEXEC) = -1 ENOENT (No such file or directory)
stat64("/usr/lib/debug", {st_mode=S_IFDIR|0755, st_size=4096, …}) = 0
mmap2(NULL, 49488, PROT_READ, MAP_PRIVATE, 3, 0) = 0x76f3f000
close(3) = 0
mmap2(NULL, 1020732, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x76e18000
mprotect(0x76efc000, 65536, PROT_NONE) = 0
mmap2(0x76f0c000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe4000) = 0x76f0c000
mmap2(0x76f0f000, 9020, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x76f0f000
close(3) = 0
set_tls(0x76f4d180) = 0
mprotect(0x76f0c000, 8192, PROT_READ) = 0
mprotect(0x76f24000, 4096, PROT_READ) = 0
mprotect(0x444000, 4096, PROT_READ) = 0
mprotect(0x76f4e000, 4096, PROT_READ) = 0
munmap(0x76f3f000, 49488) = 0
openat(AT_FDCWD, “./a.out”, O_RDONLY) = 3
read(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\375\3\0\0004\0\0\0”…, 4096) = 4096
close(3) = 0
brk(0x1551000) = 0x1551000
readlink("/proc/self/exe", “/usr/bin/valgrind.bin”, 500) = 21
execve("/usr/lib/arm-linux-gnueabihf/valgrind/memcheck-arm-linux", ["/usr/bin/valgrind.bin", “./a.out”], 0x1530378 / 36 vars /) = 0
open("/proc/self/maps", O_RDONLY) = 3
read(3, "58000000-58263000 r-xp 00000000 "…, 100000) = 540
read(3, “”, 99460) = 0
close(3) = 0
mmap2(0x4156f000, 4194304, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, 0, 0) = 0x4156f000
ugetrlimit(RLIMIT_DATA, {rlim_cur=RLIM_INFINITY, rlim_max=RLIM_INFINITY}) = 0
ugetrlimit(RLIMIT_STACK, {rlim_cur=81921024, rlim_max=RLIM_INFINITY}) = 0
rt_sigprocmask(SIG_UNBLOCK, [ILL FPE], , 8) = 0
rt_sigaction(SIGILL, NULL, {sa_handler=SIG_DFL, sa_mask=, sa_flags=0}, 8) = 0
rt_sigaction(SIGFPE, NULL, {sa_handler=SIG_DFL, sa_mask=, sa_flags=0}, 8) = 0
rt_sigaction(SIGILL, {sa_handler=0x58053b18, sa_mask=, sa_flags=SA_NODEFER}, NULL, 8) = 0
rt_sigaction(SIGFPE, {sa_handler=0x58053b18, sa_mask=, sa_flags=SA_NODEFER}, NULL, 8) = 0
rt_sigaction(SIGILL, {sa_handler=SIG_DFL, sa_mask=, sa_flags=0}, NULL, 8) = 0
rt_sigaction(SIGFPE, {sa_handler=SIG_DFL, sa_mask=, sa_flags=0}, NULL, 8) = 0
rt_sigprocmask(SIG_SETMASK, , NULL, 8) = 0
getcwd("/HDD/projects/HelloWorld", 499) = 25
open("/home/osmc/.valgrindrc", O_RDONLY) = -1 ENOENT (No such file or directory)
open("./.valgrindrc", O_RDONLY) = -1 ENOENT (No such file or directory)
open("./a.out", O_RDONLY) = 3
stat64("./a.out", {st_mode=S_IFREG|0755, st_size=8136, …}) = 0
getxattr("./a.out", “security.capability”, NULL, 0) = -1 ENODATA (No data available)
geteuid32() = 1000
fstat64(3, {st_mode=S_IFREG|0755, st_size=8136, …}) = 0
pread64(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\375\3\0\0004\0\0\0”…, 4096, 0) = 4096
pread64(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\375\3\0\0004\0\0\0”…, 52, 0) = 52
pread64(3, “\1\0\0p\204\5\0\0\204\5\0\0\204\5\0\0\10\0\0\0\10\0\0\0\4\0\0\0\4\0\0\0”…, 288, 52) = 288
pread64(3, “/lib/ld-linux-armhf.so.3\0”, 25, 340) = 25
open("/lib/ld-linux-armhf.so.3", O_RDONLY) = 4
pread64(4, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0@\n\0\0004\0\0\0”…, 52, 0) = 52
pread64(4, “\1\0\0p\230z\1\0\230z\1\0\230z\1\0\260\0\0\0\260\0\0\0\4\0\0\0\4\0\0\0”…, 224, 52) = 224
mmap2(0x108000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x108000
readlink("/proc/self/fd/3", “/HDD/projects/HelloWorld/a.out”, 4096) = 30
mmap2(0x118000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x118000
mmap2(0x4000000, 98304, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 4, 0) = 0x4000000
fstat64(4, {st_mode=S_IFREG|0755, st_size=105844, …}) = 0
readlink("/proc/self/fd/4", “/lib/arm-linux-gnueabihf/ld-2.28”…, 4096) = 35
mmap2(0x4028000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 4, 0x18000) = 0x4028000
close(4) = 0
close(3) = 0
access("/usr/lib/arm-linux-gnueabihf/valgrind/vgpreload_memcheck-arm-linux.so", R_OK) = 0
mmap2(0x7dadc000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, 0, 0) = 0x7dadc000
munmap(0x7eb3d000, 4096) = 0
mmap2(0x402a000, 4096, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, 0, 0) = 0x402a000
ugetrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=10241024}) = 0
setrlimit(RLIMIT_NOFILE, {rlim_cur=1036, rlim_max=10241024}) = 0
fcntl(3, F_DUPFD, 1024) = 1024
close(3) = 0
fcntl(1024, F_SETFD, FD_CLOEXEC) = 0
getpid() = 24413
getpid() = 24413
getppid() = 24409
open("/tmp/valgrind_proc_24413_cmdline_76fef51e", O_RDWR|O_CREAT|O_EXCL|O_TRUNC, 0600) = 3
fcntl(3, F_DUPFD, 1024) = 1025
close(3) = 0
fcntl(1025, F_SETFD, FD_CLOEXEC) = 0
write(1025, “./a.out”, 7) = 7
write(1025, “\0”, 1) = 1
unlink("/tmp/valgrind_proc_24413_cmdline_76fef51e") = 0
getpid() = 24413
getpid() = 24413
getppid() = 24409
open("/tmp/valgrind_proc_24413_auxv_76fef51e", O_RDWR|O_CREAT|O_EXCL|O_TRUNC, 0600) = 3
fcntl(3, F_DUPFD, 1024) = 1026
close(3) = 0
fcntl(1026, F_SETFD, FD_CLOEXEC) = 0
write(1026, “\1\0\0\0\0\320\263~\20\0\0\0\326\260?\0\6\0\0\0\0\20\0\0\21\0\0\0d\0\0\0”…, 160) = 160
unlink("/tmp/valgrind_proc_24413_auxv_76fef51e") = 0
mmap2(0x4196f000, 4194304, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, 0, 0) = 0x4196f000
fcntl(2, F_DUPFD, 1024) = 1027
fcntl(1027, F_SETFD, FD_CLOEXEC) = 0
clock_gettime(CLOCK_MONOTONIC, {tv_sec=51774, tv_nsec=75007759}) = 0
getpid() = 24413
write(1027, “==24413== Memcheck, a memory err”…, 44==24413== Memcheck, a memory error detector
) = 44
getpid() = 24413
write(1027, “==24413== Copyright (C) 2002-201”…, 74==24413== Copyright (C) 2002-2017, and GNU GPL’d, by Julian Seward et al.
) = 74
getpid() = 24413
write(1027, “==24413== Using Valgrind-3.14.0 “…, 77==24413== Using Valgrind-3.14.0 and LibVEX; rerun with -h for copyright info
) = 77
getpid() = 24413
write(1027, “==24413== Command: ./a.out\n”, 27==24413== Command: ./a.out
) = 27
getpid() = 24413
write(1027, “==24413== \n”, 11==24413==
) = 11
mmap2(0x41d6f000, 500000, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, 0, 0) = 0x41d6f000
mmap2(0x41dea000, 1048576, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, 0, 0) = 0x41dea000
stat64(”/HDD/projects/HelloWorld/a.out”, {st_mode=S_IFREG|0755, st_size=8136, …}) = 0
open("/HDD/projects/HelloWorld/a.out", O_RDONLY|O_NOFOLLOW) = 3
pread64(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\375\3\0\0004\0\0\0”…, 1024, 0) = 1024
close(3) = 0
stat64("/HDD/projects/HelloWorld/a.out", {st_mode=S_IFREG|0755, st_size=8136, …}) = 0
close(3) = 0
open("/HDD/projects/HelloWorld/a.out", O_RDONLY) = 3
pread64(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0\375\3\0\0004\0\0\0”…, 8136, 0) = 8136
open("/usr/lib/debug/.build-id/ee/203f96532854d379401f54eabe05c25076c126.debug", O_RDONLY) = -1 ENOENT (No such file or directory)
close(3) = 0
mmap2(0x41eea000, 65536, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, 0, 0) = 0x41eea000
stat64("/lib/arm-linux-gnueabihf/ld-2.28.so", {st_mode=S_IFREG|0755, st_size=105844, …}) = 0
open("/lib/arm-linux-gnueabihf/ld-2.28.so", O_RDONLY|O_NOFOLLOW) = 3
pread64(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0@\n\0\0004\0\0\0”…, 1024, 0) = 1024
close(3) = 0
close(3) = 0
open("/lib/arm-linux-gnueabihf/ld-2.28.so", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0755, st_size=105844, …}) = 0
pread64(3, “\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0(\0\1\0\0\0@\n\0\0004\0\0\0”…, 8192, 0) = 8192
pread64(3, “\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0”…, 7540, 98304) = 7540
open("/usr/lib/debug/.build-id/e6/c80bf7a6ac41070833da70cd457e3255886dcc.debug", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/c80bf7a6ac41070833da70cd457e3255886dcc.debug", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/arm-linux-gnueabihf/.debug/c80bf7a6ac41070833da70cd457e3255886dcc.debug", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/debug/lib/arm-linux-gnueabihf/c80bf7a6ac41070833da70cd457e3255886dcc.debug", O_RDONLY) = -1 ENOENT (No such file or directory)
close(3) = 0
write(1027, “\n”, 1
) = 1
write(1027, “valgrind: Fatal error at startu”…, 58valgrind: Fatal error at startup: a function redirection
) = 58
write(1027, “valgrind: which is mandatory fo”…, 65valgrind: which is mandatory for this platform-tool combination
) = 65
write(1027, “valgrind: cannot be set up. De”…, 62valgrind: cannot be set up. Details of the redirection are:
) = 62
write(1027, “valgrind: \n”, 12valgrind:
) = 12
write(1027, "valgrind: A must-be-redirected "…, 41valgrind: A must-be-redirected function
) = 41
write(1027, “valgrind: whose name matches th”…, 54valgrind: whose name matches the pattern: index
) = 54
write(1027, “valgrind: in an object with son”…, 68valgrind: in an object with soname matching: ld-linux-armhf.so.3
) = 68
write(1027, "valgrind: was not found whilst "…, 43valgrind: was not found whilst processing
) = 43
write(1027, “valgrind: symbols from the obje”…, 68valgrind: symbols from the object with soname: ld-linux-armhf.so.3
) = 68
) = 12
write(1027, “valgrind: Possible fixes: (1, s”…, 70valgrind: Possible fixes: (1, short term): install glibc’s debuginfo
) = 70
write(1027, “valgrind: package on this machi”…, 73valgrind: package on this machine. (2, longer term): ask the packagers
) = 73
write(1027, “valgrind: for your Linux distri”…, 71valgrind: for your Linux distribution to please in future ship a non-
) = 71
write(1027, “valgrind: stripped ld.so (or wh”…, 73valgrind: stripped ld.so (or whatever the dynamic linker .so is called)
) = 73
write(1027, “valgrind: that exports the abov”…, 68valgrind: that exports the above-named function using the standard
) = 68
write(1027, “valgrind: calling conventions f”…, 72valgrind: calling conventions for this platform. The package you need
) = 72
write(1027, “valgrind: to install for fix (1”…, 44valgrind: to install for fix (1) is called
) = 44
) = 12
write(1027, "valgrind: On Debian, Ubuntu: "…, 58valgrind: On Debian, Ubuntu: libc6-dbg
) = 58
write(1027, "valgrind: On SuSE, openSuSE, "…, 64valgrind: On SuSE, openSuSE, Fedora, RHEL: glibc-debuginfo
) = 64
) = 12
write(1027, "valgrind: Note that if you are "…, 64valgrind: Note that if you are debugging a 32 bit process on a
) = 64
write(1027, “valgrind: 64 bit system, you wi”…, 73valgrind: 64 bit system, you will need a corresponding 32 bit debuginfo
) = 73
write(1027, “valgrind: package (e.g. libc6-d”…, 42valgrind: package (e.g. libc6-dbg:i386).
) = 42
) = 12
write(1027, “valgrind: Cannot continue – ex”…, 51valgrind: Cannot continue – exiting now. Sorry.
) = 51
write(1027, “\n”, 1
) = 1
exit_group(1) = ?
+++ exited with 1 +++
I am not able from that how to proceed or fix this.
