Nabbed some logs after my ongoing vanishing osmc GUI/vanishing AEC issue which seems to come around every few days. Is there anything here?
Could you give some context regarding the issue you are experiencing?
Checked your post issue but didn’t see a recent thread.
Yes
Vero 4K= working fine until kodi upgrade. After 20.5 Vero 4K+ not showing up as an available device to switch to on the TV; osmc GUI dissapears completely. ARC stops working. This makes makes capturing debug logs difficult as there is no access to the Vero GUI.
I have to unplug from wall mains every few days to get things to ‘restart’. Sometimes pulling out the Vero lead and hdmi lead works but if and only if the front red-light briefly flashes on when plugged back in after 30 mins. A lot of the time it does not do this.
Have tried Lindy HDMI CEC Less Adapter but no joy.
Seems to be ‘AML no longer support SoC in the Vero 4K+’ issue.
I am trying to install Kodi Mar 2022 version
https://ftp.fau.de/osmc/osmc/download//installers/diskimages/OSMC_TGT_vero3_20220314.img.gz
but having trouble booting off USB stick.
Understood.
How are you imaging the USB stick?
Maybe you can show us a screenshot of the contents of the USB so we can make sure you imaged it correctly?
Here’s a shot of the usb stick when flashed
I’m on a Mac
I download Kodi Mar 2022 version
Click on it to open as .img file
Flash the .img to usbstick using Etcher
usb stick into Vero procedure
no downgrade
Use the installer from Download - OSMC
If you are clicking dtb.img it won’t work. Can you clarify?
Picture shows Mac destop.
NO NAME is the usb stick.
kernel/filesystem/dtb have been fashed to this usbstick from
usb stick ist then taken from Mac
to be inserted into Vero to go through install Kodi from March 2024
Can you upload the output of the log file? It should be in the home folder
For first time, managed to get installer on to USB stick.
Took out Vero power, put in usb booted back up - blue screen but no install steps, no instruction screens just reverts to kodi 20.5
Sun Mar 23 17:12:51 2025 Download successful
Sun Mar 23 17:12:52 2025 Extracting /Users/maddox/OSMC_TGT_vero3_20240920.img.gz
Sun Mar 23 17:12:53 2025 Finished extraction. Going to write image
Sun Mar 23 17:12:53 2025 Requesting confirmation from user
Sun Mar 23 17:13:15 2025 User confirmed
Sun Mar 23 17:13:15 2025 going to start osa
Sun Mar 23 17:13:15 2025 pasting admin script to process do shell script “SUDO_ASKPASS=…/MacOS/sudo-askpass.osascript.js sudo -A /bin/dd if=/Users/maddox/OSMC_TGT_vero3_20240920.img of=/dev/rdisk3 bs=1m conv=sync && sync”
Sun Mar 23 17:13:15 2025 waiting for finish
Sun Mar 23 17:14:51 2025 osa claims to be done…collect output and verify
Sun Mar 23 17:14:51 2025 Imaging was successful
Sun Mar 23 17:14:51 2025 Image successfully written to media
Sun Mar 23 17:14:51 2025 Deleting the uncompressed image to save space
Can you show me a screenshot of the contents of the USB so I can check it was imaged correctly?
Managed to revert to Kodi Mar 2022 version finally.
Couldn’t get Vero to reinstall Kodi 19.5 with any USB sticks. Answer was to use miniSD card.
Somewhere in the threads it’s mentioned that Vero was actually designed to use miniSD card …
Got a SanDisk miniSD Card. Dragged OSMC_TGT_vero3_20220314 2 onto it. Booted up Vero 4k+ with SD card inserted. Went through sign on process. Relaunched backup settings saved to ext HDD. All working. No more missing OSMC GUI issues as with Kodi 20.5.
That wouldn’t work.
You would need to write the image. The most easy way would be using the OSMC installer.
How do I write the image using the OSMC installer?
And how do I then make sure I’m using Kodi Mar 2022 version?
If you’re still experiencing an issue, please let us know
Hi Sam
Only just got the hang of writing image using OSMC installer, pointing it to Kodi 19.4 file via dropdown ‘point to local build on my computer’ - then copying to SanDisk mini card and then booting Vero 4k with card installed. Really couldn’t get the hang of it.
But, Initially, reverting to Kodi 19.4 did indeed stop the issues of the osmc GUI vanishing. However problems recurred within a few days. Still having to pull Vero 4k power cable out everyday to make anything work. And even then it can take several tries before GUI returns.
I only use Vero with a local information setup - I prefer to generate the nfo myself and make my own posters/fanart. No add ons or PVR. Very minimalistic. But reverting hasn’t worked for me. Mulling over Vero 5.
Try enable HPD Lock under Settings → Display.
Then reboot the device.
Tried this and - amazingly - everything has been good for last ten days!
Will monitor for next few weeks and report back.
