Various issues with Vero 4k
Hi @sam_nazarko,
tested and I can confirm the “stop / buffering” at around 1:48 is gone!
Boris
Thanks for confirming. I’ll make a kernel with some improvements available for testing shortly.
Will the setting remain until I reboot the vero?
I am testing other 4K material having micro stutters as well, maybe this will solve more issues than currently expected.
Boris
It’s not persistent. I’ll make a test thread available in a couple of hours and would like it if you could test then.
you bet!
Willing to help, too
I can confirm that the first stop/buffering in Serenity is gone, too! I do a short look…
Sam,
you made my day today.
I was one of the users suffering micro stutters when playing high bit files.
I followed tons of suggestions in regards to advancedsettings playing with videocache and readspeed.
Even a gigabit adapter was bought to get rid of the problems.
After quickly checking with JohnWick2 and your recommendation i can confirm no stuttering in the movie anymore.
Further i deleted my advancedsettings.xml file and now run the vero4k pure as designed and guess what: All high bit files >80 run smoothly without stuttering or audio drops…
Maybe i cheer-up to early but for me still a good day!
cheers
Boris
Nice! Great work everyone, I’ll try this later too if I get a chance. Really encouraging results though, thanks Sam.
John Wick 2 seems fine after running the command - both the m2ts and mkv clips I posted above play back ok.
Serenity also plays ok in terms of the freeze but has some visual corruption on screen - and the source m2ts is a mess, jetliner frames and green blobs. I’ll get a log up tomorrow plus some screens /video.
Great start though!
Edit: seems the corruption is only when skipping ahead, I jumped to the 3 minute mark to see the freezing area.
Please test: Playback improvements for 4K HEVC UHD content
I’ll close this thread for now as it seems to have served its purpose.
