I’m getting my Vero 4K boxes tomorrow and I was wondering if anyone knows if VC 1 codec is supported? I got some mkv blu ray videos that use that codec and they are stuttering on my current android box. I really hope it’s supported on Vero 4K.
They should play fine on your Vero 4K.
Awesome! Will report back tomorrow with hopefully good news
UPDATE: All VC 1 files are slow
All my other h264 files that I used makemkv on works perfectly. They are all ripped from my original bly ray discs using makemkv. So I have the same problem with Vero 4K that I had with my Minix U1.
