Thanks for the reply! To be honest, i don’t mind/care if i only get 8bit playback, so long as it does play the video. Here’s the mediainfo for an example file:
General
Count : 322
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Inform : Matroska: 354 MiB, 42mn 27s
Unique ID : 205402766706707578500682154991397030570
Unique ID : 205402766706707578500682154991397030570 (0x9A872247AA9D0386A3E784A83F8ACAAA)
Count of video streams : 1
Count of audio streams : 2
Count of text streams : 2
Video_Format_List : HEVC
Video_Format_WithHint_List : HEVC
Codecs Video : V_MPEGH/ISO/HEVC
Video_Language_List : English
Audio_Format_List : AAC / AAC
Audio_Format_WithHint_List : AAC / AAC
Audio codecs : AAC LC-SBR / AAC LC-SBR
Audio_Language_List : English / English
Text_Format_List : UTF-8 / UTF-8
Text_Format_WithHint_List : UTF-8 / UTF-8
Text codecs : UTF-8 / UTF-8
Text_Language_List : English / English
Complete name :
Folder name :
File name : Castle S08E09 Tone Death (1080p x265 10bit Joy)
File extension : mkv
Format : Matroska
Format : Matroska
Format/Url : http://packs.matroska.org/
Format/Extensions usually used : mkv mk3d mka mks
Commercial name : Matroska
Format version : Version 4 / Version 2
Codec : Matroska
Codec : Matroska
Codec/Url : http://packs.matroska.org/
Codec/Extensions usually used : mkv mk3d mka mks
File size : 370980975
File size : 354 MiB
File size : 354 MiB
File size : 354 MiB
File size : 354 MiB
File size : 353.8 MiB
Duration : 2547504
Duration : 42mn 27s
Duration : 42mn 27s 504ms
Duration : 42mn 27s
Duration : 00:42:27.504
Duration : 00:42:28;03
Duration : 00:42:27.504 (00:42:28;03)
Overall bit rate : 1165002
Overall bit rate : 1 165 Kbps
Frame rate : 23.976
Frame rate : 23.976 fps
Frame count : 61079
Stream size : 810878
Stream size : 792 KiB (0%)
Stream size : 791.9 KiB
Proportion of this stream : 0.00219
Encoded date : UTC 2016-02-10 06:32:15
File last modification date : UTC 2016-05-25 18:29:00
File last modification date (local) : 2016-05-25 20:29:00
Writing application : mkvmerge v8.4.0 (‘A better way to fly’) 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Count : 341
Kind of stream : Video
StreamOrder : 0
Inform : 911 Kbps, 19201080 (16:9), at 23.976 (24000/1001) fps, HEVC (Main 10@L4@Main)
Unique ID : 800796986569418642
Format : HEVC
Format/Url : http://www.itu.int
Commercial name : HEVC
Format profile : Main 10@L4@Main
Internet media type : video/H265
Codec ID : V_MPEGH/ISO/HEVC
Codec : V_MPEGH/ISO/HEVC
Codec profile : Main 10@L4@Main
Duration : 2547504.000000
Duration : 42mn 27s
Duration : 42mn 27s
Bit rate : 910848
Bit rate : 911 Kbps
Width : 1920
Width : 1 920 pixels
Height : 1080
Height : 1 080 pixels
Sampled_Width : 1920
Sampled_Height : 1080
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Display aspect ratio : 16:9
Frame rate mode : CFR
Frame rate mode : Constant
Frame rate : 23.976
Frame rate : 23.976 (24000/1001) fps
FrameRate_Num : 24000
FrameRate_Den : 1001
Frame count : 61079
Resolution : 10
Resolution : 10 bits
Colorimetry : 4:2:0
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10
Bit depth : 10 bits
Bits/(PixelFrame) : 0.018
Delay : 0
Delay : 00:00:00.000
Delay, origin : Container
Stream size : 290048824
Stream size : 277 MiB (78%)
Stream size : 276.6 MiB
Proportion of this stream : 0.78184
Writing library : x265 - 1.8+38-fe65544b6c40:[Windows][GCC 4.8.2][64 bit] 10bit
Writing library : x265 1.8+38-fe65544b6c40:[Windows][GCC 4.8.2][64 bit] 10bit
Encoded_Library_Name : x265
Encoded_Library_Version : 1.8+38-fe65544b6c40:[Windows][GCC 4.8.2][64 bit] 10bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=15 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=0 / ref=2 / limit-refs=0 / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=2 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=910 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Default : Yes
Forced : No
Forced : No
Audio #1
Count : 279
Count of stream of this kind : 2
Kind of stream : Audio
Stream identifier : 1
StreamOrder : 1
Inform : English, 198 Kbps, 48.0 KHz / 24.0 KHz, 6 channels, AAC (HE-AAC / LC)
Unique ID : 2614048780137289653
Format : AAC
Format/Info : Advanced Audio Codec
Commercial name : AAC
Format profile : HE-AAC / LC
Format settings, SBR : Yes (Implicit)
Format settings, PS : No (Explicit)
Codec ID : A_AAC
Codec : AAC LC-SBR
Codec : AAC LC-SBR
Codec/Family : AAC
Duration : 2547456.000000
Duration : 42mn 27s
Duration : 42mn 27s 456ms
Duration : 42mn 27s
Duration : 00:42:27.456
Duration : 00:43:15:21
Duration : 00:42:27.456 (00:43:15:21)
Bit rate : 197649
Bit rate : 198 Kbps
Channel(s) : 6
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Channel positions : 3/2/0.1
ChannelLayout : C L R Ls Rs LFE
Samples per frame : 1024
Sampling rate : 48000 / 24000
Sampling rate : 48.0 KHz / 24.0 KHz
Samples count : 122277888
Frame rate : 23.438
Frame rate : 23.438 fps (1024 spf)
Frame count : 59706
Compression mode : Lossy
Delay : 31
Delay : 31ms
Delay : 31ms
Delay : 31ms
Delay : 00:00:00.031
Delay relative to video : 31
Delay relative to video : 31ms
Delay relative to video : 00:00:00.031
Video0 delay : 31
Video0 delay : 31ms
Video0 delay : 31ms
Video0 delay : 31ms
Video0 delay : 00:00:00.031
Stream size : 62937860
Stream size : 60.0 MiB (17%)
Stream size : 60 MiB
Stream size : 60.02 MiB
Proportion of this stream : 0.16965
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Default : Yes
Default : Yes
Forced : No
Forced : No
Audio #2
Count : 279
Stream identifier : 2
StreamOrder : 2
Inform : English, 53.7 Kbps, 48.0 KHz / 24.0 KHz, 2 channels, AAC (HE-AAC / LC)
Unique ID : 15702708579779658421
Format : AAC
Codec ID : A_AAC
Codec : AAC LC-SBR
Codec : AAC LC-SBR
Codec/Family : AAC
Duration : 42mn 27s
Duration : 42mn 27s
Bit rate : 53664
Bit rate : 53.7 Kbps
Channel(s) : 2
Channel(s) : 2 channels
Channel positions : Front: L R
Channel positions : 2/0/0
ChannelLayout : L R
Frame rate : 23.438
Frame count : 59706
Delay : 31
Delay : 31ms
Delay : 31ms
Delay : 31ms
Video0 delay : 31
Video0 delay : 31ms
Video0 delay : 31ms
Video0 delay : 31ms
Stream size : 17088641
Stream size : 16.3 MiB (5%)
Stream size : 16 MiB
Stream size : 16.30 MiB
Proportion of this stream : 0.04606
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Default : No
Default : No
Forced : No
Forced : No
Text #1
Count : 241
Kind of stream : Text
StreamOrder : 3
Inform : English, UTF-8
Unique ID : 749473837771647125
Format : UTF-8
Commercial name : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Codec : S_TEXT/UTF8
Codec : UTF-8
Codec/Info : UTF-8 Plain Text
Duration : 2517914.000000
Duration : 41mn 57s
Duration : 41mn 57s 914ms
Duration : 41mn 57s
Duration : 00:41:57.914
Bit rate : 150
Bit rate : 150 bps
Frame rate : 0.421
Frame rate : 0.421 fps
Frame count : 1060
Count of elements : 1060
Stream size : 47386
Stream size : 46.3 KiB (0%)
Stream size : 46 KiB
Stream size : 46.28 KiB
Proportion of this stream : 0.00013
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Default : No
Default : No
Forced : No
Forced : No
Text #2
Count : 241
StreamOrder : 4
Unique ID : 9253120762191510971
Format : UTF-8
Codec : S_TEXT/UTF8
Codec : UTF-8
Duration : 41mn 57s
Duration : 41mn 57s
Bit rate : 150
Bit rate : 150 bps
Frame rate : 0.421
Frame count : 1060
Stream size : 47386
Language : en
Language : English
Language : English
Language : en
Language : eng
Language : en
Default : No
Default : No
Forced : No
Forced : No
