Hi guys!
I updated my home cinema with Atmos speakers. Now I tried to get some trailers to hear my new cinema sound with my Denon x4200 - won´t work.
I get no atmos or DTS:X Signal from the Vero to my AVR. I also tried to play the files via my PC (VLC) to my AVR - everything works.
I´m on it a few hours but can´t get this issue solved. Can anyone help me in this case why I get no Atmos via Vero 4K to my AVR?
Did it work before the most recent update? There were some changes there.
Did you configure audio correctly to enable passthrough; and do other formats work correctly?
Sure. I made the latest update. My AVR plays “only” 7.1 Multichannel. Also when I play TrueHD it also displays “PCM” 7.1 Multichannel.
Only via Vero 4K, with my PC there is always displayed the correct sound format.
I think I tried each config…
Are you saying it doesn’t support HD audio passthrough? This is required for Atmos to work.
You can enable DTS TrueHD passthrough in Kodi settings provided that your
amp supports it. TrueHD can be decoded losslessly and streamed as LPCM, which
is why it works with passthrough disabled. Atmos cannot; which is why we pass it through
to the AVR (the way it’s meant to be done for best audio quality anyway)
I only get (when I turn on “auto” on the AVR) a Multichannel 7.1. When I play True HD or DTS Master Audio from the PC or from my other devices (before iI got the Vero) the AVR turns to this mode.
I switched the Vero to passtrough and plugged in a 4k compatible HDMI cable.
Okay. A bit more information is needed so we can work out why that’s happening. The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here.
It will also help if you can take some photos or screenshots of the audio settings so I can see if anything is amiss.
So I have tested several cabels, serveral HDMI inputs, also Firmware from 04/2017, 05/2017 and the brand new. Always the same issue - No Atmos and DTS:X
I have received the Verto 4k+. Thank you.
After installation it applied an update and reboot. Ok-
Almost everything works correctly but the Atmos Audio.
Vero is sitting side by side with my X96 Max running Coreelec.
Audio in both devices is set to passtrough. While in Coreelec I see all the audio types after enabling passtrough and check everything, in Osmc after enabling passtrough, there is no audio format to check .
So I thought that it allowed all the supported formats to passthrough.
Then I played a 4k Hdr movie with Dolby Atmos track but the system did not recognize it as Dolby Atmos, altough it was played (maybe in pcm?).
Same movie played trough the X96 Max/Coreelec activated the Dolby Atmos logo and audio.
Same setup same components. As said both the Vero and the X96 are sitting side by side and connected to the same system. To be sure I also used the same Hdmi port for test. No way to get Atmos.
For your information the Vero is running on kodi 18.3 compiled 2019-08-05
Make sure you are scrolling down below the passthrough setting. You can also try setting to expert menus in the lower left corner of that settings menu.
