Hi all,
I would like to be able to watch floatplane.com content on my Vero 4k. I know there is a way to watch it with a plex server, so it should be able to watch it on Kodi too.
Thank you for your help.
Here is a addon for kodi, worked with pi3 so it should work with Vero4k
Download the zip and install it in kodi
Thank you I will try it out
Hi! I installed the zip file and now i can see the plugin, but when i try to go to it I just get an error, and it tells me to check the logs, but where are they in kodi ?
Also should I just configure the plugin with my login and password for floatplane ?
Also also, does the plugin work if you have two factor auth ?
Thanks!
They would be part of Kodi’s log but they may not show much unless you enable debug before trying to open it. You can access the Kodi log by going to ~/.kodi/temp/kodi.log or you can just upload them via the My OSMC add-on which will give you a url that you can view in any web browser.
Here is the error messages I get, do that mean anything to you ? Thanks!
2021-01-24 15:01:52.955 T:4070887440 NOTICE: ADDON: plugin.video.floatplaneclub v1.0.3 installed
File "/home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py", line 94, in <module>
File "/home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py", line 60, in show_page
File "/home/osmc/.kodi/addons/plugin.video.floatplaneclub/resources/lib/scraper.py", line 74, in get_videos
2021-01-24 15:03:05.498 T:3609149664 ERROR: GetDirectory - Error getting plugin://plugin.video.floatplaneclub/2/
2021-01-24 15:03:05.514 T:4070887440 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.floatplaneclub/2/) failed
2021-01-24 15:13:00.838 T:3932152032 DEBUG: GetImageHash - unable to stat url /home/osmc/.kodi/addons/plugin.video.floatplaneclub/fanart.jpg
2021-01-24 15:13:01.578 T:4070887440 DEBUG: Clearing cached fileitems [plugin://plugin.video.floatplaneclub/]
2021-01-24 15:13:01.578 T:4070887440 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.floatplaneclub/)
2021-01-24 15:13:01.635 T:3932152032 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.floatplaneclub] took 56 ms
2021-01-24 15:13:01.635 T:3940544736 DEBUG: StartScript - calling plugin Floatplane Club('plugin://plugin.video.floatplaneclub/','3','','resume:false')
2021-01-24 15:13:01.636 T:3966939360 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): start processing
2021-01-24 15:13:01.876 T:3966939360 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): the source file to load is "/home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py"
2021-01-24 15:13:01.877 T:3966939360 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.floatplaneclub:/home/osmc/.kodi/addons/script.module.beautifulsoup4/lib:/home/osmc/.kodi/addons/script.module.certifi/lib:/home/osmc/.kodi/addons/script.module.chardet/lib:/home/osmc/.kodi/addons/script.module.idna/lib:/home/osmc/.kodi/addons/script.module.requests/lib:/home/osmc/.kodi/addons/script.module.urllib3/lib:/home/osmc/.kodi/addons/script.module.xbmcswift2/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/gtk-2.0
2021-01-24 15:13:01.877 T:3966939360 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): entering source directory /home/osmc/.kodi/addons/plugin.video.floatplaneclub
2021-01-24 15:13:01.877 T:3966939360 DEBUG: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): instantiating addon using automatically obtained id of "plugin.video.floatplaneclub" dependent on version 2.1.0 of the xbmc.python api
2021-01-24 15:13:03.318 T:3966939360 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: loading setting definitions
2021-01-24 15:13:03.318 T:3966939360 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: trying to load setting definitions from old format...
2021-01-24 15:13:06.058 T:3966939360 INFO: CPythonInvoker(4, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): script successfully run
2021-01-24 15:13:06.058 T:3966939360 DEBUG: onExecutionDone(4, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py)
2021-01-24 15:13:06.074 T:4070887440 DEBUG: Saving fileitems [plugin://plugin.video.floatplaneclub/]
2021-01-24 15:13:15.609 T:4070887440 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.floatplaneclub/2/)
2021-01-24 15:13:15.609 T:4070887440 DEBUG: ParentPath = [plugin://plugin.video.floatplaneclub/]
2021-01-24 15:13:15.664 T:3609149664 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.floatplaneclub] took 55 ms
2021-01-24 15:13:15.665 T:3966939360 DEBUG: StartScript - calling plugin Floatplane Club('plugin://plugin.video.floatplaneclub/2/','4','','resume:false')
2021-01-24 15:13:15.665 T:3940544736 DEBUG: CPythonInvoker(5, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): start processing
2021-01-24 15:13:15.900 T:3940544736 DEBUG: CPythonInvoker(5, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): the source file to load is "/home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py"
2021-01-24 15:13:15.901 T:3940544736 DEBUG: CPythonInvoker(5, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.floatplaneclub:/home/osmc/.kodi/addons/script.module.beautifulsoup4/lib:/home/osmc/.kodi/addons/script.module.certifi/lib:/home/osmc/.kodi/addons/script.module.chardet/lib:/home/osmc/.kodi/addons/script.module.idna/lib:/home/osmc/.kodi/addons/script.module.requests/lib:/home/osmc/.kodi/addons/script.module.urllib3/lib:/home/osmc/.kodi/addons/script.module.xbmcswift2/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/gtk-2.0
2021-01-24 15:13:15.901 T:3940544736 DEBUG: CPythonInvoker(5, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): entering source directory /home/osmc/.kodi/addons/plugin.video.floatplaneclub
2021-01-24 15:13:15.901 T:3940544736 DEBUG: CPythonInvoker(5, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): instantiating addon using automatically obtained id of "plugin.video.floatplaneclub" dependent on version 2.1.0 of the xbmc.python api
2021-01-24 15:13:17.403 T:3940544736 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: loading setting definitions
2021-01-24 15:13:17.403 T:3940544736 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: trying to load setting definitions from old format...
2021-01-24 15:13:21.187 T:3940544736 DEBUG: onExecutionDone(5, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py)
2021-01-24 15:13:21.331 T:3966939360 ERROR: GetDirectory - Error getting plugin://plugin.video.floatplaneclub/2/
2021-01-24 15:13:21.341 T:4070887440 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.floatplaneclub/2/) failed
2021-01-24 15:13:21.341 T:4070887440 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.floatplaneclub/)
2021-01-24 15:13:21.342 T:4070887440 DEBUG: Loading items: 1, directory: plugin://plugin.video.floatplaneclub/ sort method: 0, ascending: false
2021-01-24 15:13:21.394 T:3609149664 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.floatplaneclub] took 53 ms
2021-01-24 15:13:24.148 T:3609149664 DEBUG: GetImageHash - unable to stat url /home/osmc/.kodi/addons/plugin.video.floatplaneclub/fanart.jpg
2021-01-24 15:20:35.327 T:3940544736 ERROR: GetDirectory - Error getting plugin://plugin.video.floatplaneclub/2/
2021-01-24 15:20:35.331 T:4070887440 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.floatplaneclub/2/) failed
2021-01-24 15:25:25.600 T:3966939360 ERROR: GetDirectory - Error getting plugin://plugin.video.floatplaneclub/2/
2021-01-24 17:54:24.777 T:3548369120 DEBUG: GetImageHash - unable to stat url /home/osmc/.kodi/addons/plugin.video.floatplaneclub/fanart.jpg
2021-01-24 17:54:26.935 T:4070887440 DEBUG: Clearing cached fileitems [plugin://plugin.video.floatplaneclub/]
2021-01-24 17:54:26.935 T:4070887440 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.floatplaneclub/)
2021-01-24 17:54:26.994 T:3548369120 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.floatplaneclub] took 59 ms
2021-01-24 17:54:26.995 T:3940544736 DEBUG: StartScript - calling plugin Floatplane Club('plugin://plugin.video.floatplaneclub/','9','','resume:false')
2021-01-24 17:54:26.996 T:3506536672 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): start processing
2021-01-24 17:54:27.241 T:3506536672 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): the source file to load is "/home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py"
2021-01-24 17:54:27.242 T:3506536672 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.floatplaneclub:/home/osmc/.kodi/addons/script.module.beautifulsoup4/lib:/home/osmc/.kodi/addons/script.module.certifi/lib:/home/osmc/.kodi/addons/script.module.chardet/lib:/home/osmc/.kodi/addons/script.module.idna/lib:/home/osmc/.kodi/addons/script.module.requests/lib:/home/osmc/.kodi/addons/script.module.urllib3/lib:/home/osmc/.kodi/addons/script.module.xbmcswift2/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/gtk-2.0
2021-01-24 17:54:27.242 T:3506536672 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): entering source directory /home/osmc/.kodi/addons/plugin.video.floatplaneclub
2021-01-24 17:54:27.243 T:3506536672 DEBUG: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): instantiating addon using automatically obtained id of "plugin.video.floatplaneclub" dependent on version 2.1.0 of the xbmc.python api
2021-01-24 17:54:28.646 T:3506536672 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: loading setting definitions
2021-01-24 17:54:28.646 T:3506536672 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: trying to load setting definitions from old format...
2021-01-24 17:54:31.633 T:3506536672 INFO: CPythonInvoker(11, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): script successfully run
2021-01-24 17:54:31.633 T:3506536672 DEBUG: onExecutionDone(11, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py)
2021-01-24 17:54:31.649 T:4070887440 DEBUG: Saving fileitems [plugin://plugin.video.floatplaneclub/]
2021-01-24 17:55:05.914 T:4070887440 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.floatplaneclub/2/)
2021-01-24 17:55:05.914 T:4070887440 DEBUG: ParentPath = [plugin://plugin.video.floatplaneclub/]
2021-01-24 17:55:05.974 T:3548369120 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.floatplaneclub] took 60 ms
2021-01-24 17:55:05.975 T:3539976416 DEBUG: StartScript - calling plugin Floatplane Club('plugin://plugin.video.floatplaneclub/2/','10','','resume:false')
2021-01-24 17:55:05.976 T:3940544736 DEBUG: CPythonInvoker(12, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): start processing
2021-01-24 17:55:06.293 T:3940544736 DEBUG: CPythonInvoker(12, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): the source file to load is "/home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py"
2021-01-24 17:55:06.294 T:3940544736 DEBUG: CPythonInvoker(12, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.floatplaneclub:/home/osmc/.kodi/addons/script.module.beautifulsoup4/lib:/home/osmc/.kodi/addons/script.module.certifi/lib:/home/osmc/.kodi/addons/script.module.chardet/lib:/home/osmc/.kodi/addons/script.module.idna/lib:/home/osmc/.kodi/addons/script.module.requests/lib:/home/osmc/.kodi/addons/script.module.urllib3/lib:/home/osmc/.kodi/addons/script.module.xbmcswift2/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/gtk-2.0
2021-01-24 17:55:06.294 T:3940544736 DEBUG: CPythonInvoker(12, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): entering source directory /home/osmc/.kodi/addons/plugin.video.floatplaneclub
2021-01-24 17:55:06.294 T:3940544736 DEBUG: CPythonInvoker(12, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py): instantiating addon using automatically obtained id of "plugin.video.floatplaneclub" dependent on version 2.1.0 of the xbmc.python api
2021-01-24 17:55:07.692 T:3940544736 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: loading setting definitions
2021-01-24 17:55:07.692 T:3940544736 DEBUG: CAddonSettings[plugin.video.floatplaneclub]: trying to load setting definitions from old format...
2021-01-24 17:55:10.941 T:3940544736 DEBUG: onExecutionDone(12, /home/osmc/.kodi/addons/plugin.video.floatplaneclub/addon.py)
2021-01-24 17:55:11.079 T:3539976416 ERROR: GetDirectory - Error getting plugin://plugin.video.floatplaneclub/2/
2021-01-24 17:55:11.084 T:4070887440 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.floatplaneclub/2/) failed
2021-01-24 17:55:11.085 T:4070887440 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.floatplaneclub/)
2021-01-24 17:55:11.085 T:4070887440 DEBUG: Loading items: 1, directory: plugin://plugin.video.floatplaneclub/ sort method: 0, ascending: false
2021-01-24 17:55:11.145 T:3506536672 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.floatplaneclub] took 60 ms
2021-01-24 17:55:22.892 T:3506536672 DEBUG: GetImageHash - unable to stat url /home/osmc/.kodi/addons/plugin.video.floatplaneclub/fanart.jpg
