I currently have a NAS, but under-use it, e.g. storing movies, music (for sonos) and running syncthing.
I’m wondering can the Vero 4K+ do something similar (and I ditch the NAS). Not sure if its ram will be adequate? I’m assuming that I would be able to plug in via USB a couple of drives. Just wondering if this is practical/advisable?
EDIT: or would I be better off building/buying a RP box with more ram etc? But more generally, can OSCM be used as a NAS in terms of attached drives and installing debian based software?
I use my Vero 4K as a NAS, plugged USB drive into it and installed SMB server and working fine. I only really use mine as a backup/sync target from the PC so performance not important to me but it works fine.
Transfer speeds will be limited by USB2.0 speed, meaning you won’t be able to read or write to the drive at more than 30-40MB/s.
You’ll need either to use drives that have their own AC power supply, or to use a powered USB hub - the Vero’s USB ports don’t produce enough current to power a drive that draws its power from USB.
If you have two drives connected to the same USB port (via a hub) then transfers from one drive to the other will be painfully slow. (And the Vero has only two USB ports).
That’s not a problem. The maximum allowed bit-rate on a 4K blu ray is 128 Megabits per second, or 16Megabytes per second. So if you can read 30-40 Megabytes per second off the drive, that’s more than twice what you need.
The USB speed is only a limitation when you’re transferring files across the network, or defragmenting a hard drive.
Hi, I just realized for the Vero to operate as a kind of NAS, it would need to be ‘always on’ in terms of attached disk access. Would that be wasteful in terms of power consumption, or does it have a low power state anyway; or can automatically set go into ‘sleep’ mode as you can do for a linux system and would it wake-up if trying to access attached drive?
The Vero4k is designed as a 24x7 device (it doesn’t have a power on/off button anyhow.
Generally power requirement is minimal but it also has a Standby Mode that put CPU governor to powersave.
Hopefully, this is my final question: The Vero 4K+ has 2gb ram. In relation to using it as a ‘NAS’, as it’s debian based, I’m assuming this is enough to run a few linux progs alongside kodi running (e.g. syncthing, duplicati).
My original plan was to use a RP device with 4 or 8gb ram (I have some linux experience), but the Vero seems a lot less hassle as it will be used by the family - the less things that go wrong with it the better.
Though checking that the Vero has enough resources to be used like a NAS.
