This is even cheaper
thanks, I’ll bear that in mind if I buy some more Vero 4K’s !
I can confirm that the Anker USB 3.0 gbit device also works out of the box: https://www.amazon.de/gp/product/B00NPJV4YY/
I picked up one of these the other day. Seems to work really well and the Vero 4k just accepted it with no issue. My iperf3 results would be a cut and paste of @ac16161 in the post above - roughly identical. Sadly, there is no manufacturer listed on the packaging or device and its listed as OEM on my local retailers website. Seems well made, aluminum case for what its worth.
USB 3.0 Hub 3 Ports 10/100/1000 Gigabit Ethernet Adapter RJ45 LAN for PC Mac
- 3-Port USB 3.0 hub
- Compatible for USB 2.0 and 3.0 standard
- Easy to use, no CD driver required
- Hub Size:80 x 53 x 17mm
- Cable Length:24.5cm
- Slim design and light weight
- Support wake-on-lan function
- Support IEEE 802.3az (Energy Efficient Ethernet)
- Support IPV4/IPV6 pack Checksum Offload Engine (COE) to reduce CPU loading
- Compatible for Windows XP/Vista/7/8/8.1/10 and Mac OS 10.6 or above (not support Surface WIN8 RT)
- Bus power or self-power with power adapter (not included)
It’s most likely a Amlogic S905.
see: Bluestacks TextNow VLC
The Ethernet adapter won’t have an AMLogic chip in it.
If you’re referring to Vero, it has S905X for 4K and S905D for 4K +]
