My logs
https://paste.osmc.tv/siluyexule
Changed the refresh ratio as you suggested.
My logs
Those settings are better.
Hard to see exact issues without debug logs. Do you have an AVR inbetween? Iām assuming not as you have passthrough disabled
In addition to the previously recommended settings you may also have to turn on the following setting with certain TVās.
System->Display->Force 422 colour subsampling
What is a AVR ? I just have vero directly plugged into my tv with hdmi cable. And my usb external harddrive plugged with usb on my vero.
Like as mentioned on my first post.
An AVR is a audio/video receiver. Have you tested this with a different cable yet?
Edit: Can you also try changing this setting to āon start/stopā like I recommended.
Adjust display refresh rate: Always
Is the hard disk formatted as NTFS? I can see some throughput issues during playback.
No i didnāt used any other cable i only got 1x. Okay where do i find this setting excatly ?
Yes, i canāt use fat32 as many files bigger than 5GB+.
I understand it is a bit of a bother to try a cable swap when you donāt have another laying around but cables can give all kinds of issues especially with higher resolution and bit depth content. The setting can be found atā¦
ok iāve enabled both of these:
however if i set the display to 1080p then i get overscan and the movie is partially offscreen (gui is fine) even when i calibrate the display. to get around this i tried to calibrate 1080p60 and 1080p24 but that didnāt help. i donāt seriously have to calibrate every resolution do i?
switching back to 2160p24 works fine.
i noticed in guisettings.xml most of the 1080p resolutions have:
<overscan>
<left>62</left>
<top>34</top>
<right>1860</right>
<bottom>1030</bottom>
</overscan>
whereas all of the 4k ones have:
<overscan>
<left>0</left>
<top>0</top>
<right>1920</right>
<bottom>1080</bottom>
</overscan>
This is where you should be checking the aspect ratio on your TV settings to ensure itās set at ājustā or ā1:1ā whatever your manufacturer calls it.
You should never use Kodi calibration settings. They will only degrade video quality. Once you have all these other settings we are advising, there should be no need. You should revert any Kodi overscan calibration you have set.
When you use the calibrate feature in Kodi it stores the settings in that file. It does this for every single resolution and refresh rate separately. You can manually edit those entries in the xml file if you wish.
TV aspect ratio was at 16:9, i set it to āOriginalā and it didnāt help, canāt find anything like pixel ratio.
Its like the TV is optimised for 4k and doesnāt work well at anything else - even though all it ever displays is 720/1080 content, it still runs in 4k mode.
16:9 and original are pixel ratio
That overscan setting in Kodi will still need to be removed. You can either run the calibration when you are at different resolution and frame rates or you can just edit the xml file to get there quicker and reboot your device to reload it.
Set Original and remove all the overscan settings you have configured on OSMC.
If still issue the post make/model of the TV and upload full logs again
