VERO 4K Bluetooth sound issues
Dear Developers,
I would like to ask if anyone has successfully managed to get the sound played through Bluetooth speakers / headphones instead of the HDMI output.
Thus far I was able to make my Bluetooth headphones connect to VERO 4k, however the icon was always red (not sure what that means) and under Kodi I was not able to select them as the sound output device.
If anyone could advise on how to do that I would greatly appreciate it.
I wish you all a pleasant day and happy holidays.
With kind regards,
J
If you have not upgraded to debian stretch, it should work using this: [Deprecated] [TESTING] Bluetooth audio streaming (A2DP)
If you enable the jessie-devel repository, you must not do an update with MyOSMC or issue apt-get dist-upgrade since BT audio does not work with the latest (testing) debian.
Edit: What I mean is you should be able to issue sudo apt-get install a2dp-app-osmc and get some BT functionality without upgrading to stretch. If you are not in a hurry, wait for the next release of OSMC.
