Hello everybody,
I just receive my new Vero 4k and I’m very happy about the product, but often video colors on TV are completely wrong:
Any ideas?
Thanks.
Carlo
Hello everybody,
Any ideas?
Thanks.
Carlo
Hi Carlo,
I think you may have similar issue to this: Selected menu items not really visible - #8 by sam_nazarko
Have you tried adjust the colour, brightness and contrast settings on the screen its self?
Thanks Tom.
Hi Tom,
usually colors are fine, both on kodi interface and watching movies. Then suddenly TV screen change colors as I posted before, so I don’t think is a problem of screen settings.
I have an Apple TV 1st gen with osmc software plugged on the same TV with no color issues at all.
Any other clues?
Thanks again.
Carlo
You have an old Phillips TV, and they are known to accidentally report support for the wrong colours. When the colours go funny, does running:
echo 1 > /sys/class/amhdmitx/amhdmitx0/output_rgb
help? If you can confirm this, it’s an easy fix.
Ok. Problem solved.
I found in another thread how to persist that command on /etc/rc.local.
Thanks to all!
Carlo
