I very much enjoy my Vero 4K except for one thing. It seems to power off several times per day. When I go to check the device, the red LED is lit. Won’t respond to the remote. I would prefer the device to be always on. Is there a setting I can check ? Or some specific form of logging that I can enable to see what’s causing the device to power down ?
Chad
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Your TV may be turning the device off via CEC
Does this happen after turning your TV off?
