hi, been having an issue with the 4kp where the remote control doesn’t appear to work anymore. Not only that though; the android app Yatse can no longer act as a navigation control either. So the Yatse app can still direct the 4kp to open the movies or TV show lists, and I can play a video from the app on the 4kp. It is just the navigation that doesn’t work.
So, I thought I’d just re-install, only that doesn’t appear to do anything for me either. Following instruction from here: Reinstalling OSMC - Vero 4K - OSMC. I get as far as putting the USB stick into the 4kp - when I start it up again, it just loads as normal.
Any ideas on either issue?
Thanks in advance!
