That is not a problematic temperature for the Vero and should not lead to crashes.
reproduce the issue
Thanks Sam, I def saw the messaged today that it shutdown because it reached critical temperatures… I’ll have to try and get the debug logs off it… The problem is reproducing it unfortunately as it always happens when i’m not around… I’ll try and set the debug logs before i go to bed tonight and see if it’s done it over night.
Is there a way to have the debug log on without it displaying screen?
HI Sam, that’s exactly what happened. the screen dropped to command line, it said critical temperature (amongst other things) around 4 or 5 times then the screen went off and the logo went red.
I’ve got the logs on now, i’ll try and run them as long as i can in the hope something happens again… As I said, i have to repower it atleast once a day (I have it on a smart plug to make it easier) so hopefully it will do it.
I believe some of the views in that skin tax the GPU quite heavily and can cause high temperatures. The good news is that we have GPU throttling in our 4.9 kernel, so this will solve any issues you have with hard lockups.
It would be good to know if using the OSMC skin solves your problems,
Apologies for not getting back to you on this one… I had debug running for 24 hours when we first spoke about this but it didn’t crash… i turned it off and low and behold it crashed the next day lol…
i’ve now got it on via advanced settings with no onscreen so i should be able to give you a log soon.
From my monitoring it went off around 09:40:51 this morning… Box was unresponsive, no output and red light on the front. At the time, nothing was playing.
So there was the fanart grabber running at that time, also a Google drive export was happening. Last I wonder what the repeating jsonrpc requests are coming from.
2020-05-22 09:38:09.001 T:3111117536 DEBUG: CWebServer[80]: request received for /jsonrpc
2020-05-22 09:39:02.281 T:3394224864 DEBUG: Previous line repeats 9 times.
2020-05-22 09:39:02.281 T:3394224864 DEBUG: [plugin.googledrive][service-export--900742432]: export_map: {}
2020-05-22 09:39:02.684 T:3816813280 DEBUG: [ script.embuary.helper ] Start new fanart grabber process
2020-05-22 09:39:03.001 T:3111117536 DEBUG: CWebServer[80]: request received for /jsonrpc
