Hello.
I’ve been having random crashes where the vero 4k+ just shutsdown. It looks like it is when there is high load in the network stack. Sometimes is transmision, sometimes is just sending to the vero through ssh (scp) a big file, or accesing via nfs…
The temperature never goes higher than 60 degrees so is not a thermal shutdown.
I have a ssd disk atached to the vero in the usb port without a hub or any external power. So it could be also related to the power drawn. But kernel messages suggest otherwise.
ene 21 21:47:23 osmcsala kernel: Call trace:
ene 21 21:47:23 osmcsala kernel: Exception stack(0xffffffc074b44740 to 0xffffffc074b44870)
ene 21 21:47:23 osmcsala kernel: 4740: ffffffc04ff53c00 0000007fffffffff ffffffc074b4f550 ffffff800912c4dc
ene 21 21:47:23 osmcsala kernel: 4760: ffffffc053b9cf00 ffffff800a814380 ffffffc050898000 ffffff800a814380
ene 21 21:47:23 osmcsala kernel: 4780: 0000000000000000 ffffff800a814380 8000000000000004 ffffff8009938f02
ene 21 21:47:23 osmcsala kernel: 47a0: 0000000000000000 ffffffc057348000 ffffffc074b447d0 ffffff80099e0538
ene 21 21:47:23 osmcsala kernel: 47c0: ffffffc057348000 ffffff80099e0454 ffffffc074b44860 ffffff80099a9dec
ene 21 21:47:23 osmcsala kernel: 47e0: 0000000000000000 ffffff800a83c000 0000000000000001 0000000000000000
ene 21 21:47:23 osmcsala kernel: 4800: 000000000000000c ffffffc074b44a9f ffffffc04fce0ed8 0000000000000000
ene 21 21:47:23 osmcsala kernel: 4820: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
ene 21 21:47:23 osmcsala kernel: 4840: 0000000000000000 0000000000000000 0000000000000000 0000000095468077
ene 21 21:47:23 osmcsala kernel: 4860: 0000000000000010 00000000cc30f388
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44910+ 32][<ffffff800912c4dc>] cgroup_get+0x34/0xe8
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44930+ 32][<ffffff8009132f4c>] cgroup_sk_alloc+0x48/0x98
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44950+ 48][<ffffff8009934ef4>] sk_clone_lock+0x148/0x254
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44980+ 48][<ffffff80099b79a8>] inet_csk_clone_lock+0x30/0xcc
ene 21 21:47:23 osmcsala kernel: [ffffffc074b449b0+ 64][<ffffff80099d09bc>] tcp_create_openreq_child+0x3c/0x348
ene 21 21:47:23 osmcsala kernel: [ffffffc074b449f0+ 80][<ffffff80099cdb34>] tcp_v4_syn_recv_sock+0xf0/0x2b4
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44a40+ 144][<ffffff80099d11d0>] tcp_check_req+0x35c/0x3dc
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44ad0+ 112][<ffffff80099d0154>] tcp_v4_rcv+0x504/0xb0c
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44b40+ 48][<ffffff80099ac370>] ip_local_deliver_finish+0x150/0x214
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44b70+ 112][<ffffff80099ac908>] ip_local_deliver+0x88/0xe8
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44be0+ 64][<ffffff80099ac5d0>] ip_rcv_finish+0x19c/0x32c
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44c20+ 128][<ffffff80099acc98>] ip_rcv+0x330/0x394
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44ca0+ 176][<ffffff800994a0b4>] __netif_receive_skb_core+0x634/0x810
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44d50+ 48][<ffffff800994aa48>] __netif_receive_skb+0x78/0x7c
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44d80+ 48][<ffffff800994aaf4>] netif_receive_skb_internal+0xa8/0xb4
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44db0+ 48][<ffffff800994b4ec>] napi_gro_receive+0x10c/0x140
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44de0+ 128][<ffffff800952b93c>] stmmac_poll+0x5d8/0x824
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44e60+ 176][<ffffff800994bcb4>] net_rx_action+0x128/0x33c
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44f10+ 144][<ffffff8009081960>] __do_softirq+0x250/0x35c
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44fa0+ 32][<ffffff80090a579c>] irq_exit+0x90/0xdc
ene 21 21:47:23 osmcsala kernel: [ffffffc074b44fc0+ 64][<ffffff80090f62fc>] __handle_domain_irq+0x88/0xbc
ene 21 21:47:23 osmcsala kernel: [ffffffc074b45000+ 64][<ffffff8009081568>] gic_handle_irq+0x68/0xa4
ene 21 21:47:23 osmcsala kernel: Exception stack(0xffffff80203a37e0 to 0xffffff80203a3910)
ene 21 21:47:23 osmcsala kernel: 37e0: 0000000000009b70 0000000000000064 0000000000000000 0000000000000000
ene 21 21:47:23 osmcsala kernel: 3800: 0000000060000000 000000001fb0f810 0000000000000c98 0000000000000278
ene 21 21:47:23 osmcsala kernel: 3820: ffffffc053a2ae80 ffffff80203a37f0 00000000000008a0 0000000000000024
ene 21 21:47:23 osmcsala kernel: 3840: 000000000000009a 0000000000000000 0000000000000000 0000000000000000
ene 21 21:47:23 osmcsala kernel: 3860: ffffff80091fd49c 0000000000000000 0000000000000000 000000001fb417b4
ene 21 21:47:23 osmcsala kernel: 3880: 000000000000bb80 0000000000000000 0000000000036ee8 ffffff800a7a50c0
ene 21 21:47:23 osmcsala kernel: 38a0: ffffff800a92a000 ffffff8009ef18e9 ffffff8009e70fb4 ffffff80203a3b40
ene 21 21:47:23 osmcsala kernel: 38c0: 0000000000000000 ffffff80203a3910 ffffff80093cf7c0 ffffff80203a3910
ene 21 21:47:23 osmcsala kernel: 38e0: ffffff80093cf7ec 0000000080000145 0000000000000000 0000000000000000
ene 21 21:47:23 osmcsala kernel: 3900: 0000007fffffffff 0000000000000000
Here are the full logs:
https://paste.osmc.tv/bihatarisu
Let me know if you need aditional data.
Thanks in advance.
