The internal hard disk is actually a emmc which seldom fails.
But @sam_nazarko might want to see if based on the logs he suggest a reinstall.
Jul 24 10:34:41 blomevero kernel: meson-mmc: mmc driver version: 3.02, 2017-05-15: New Emmc Host Controller
Jul 24 10:34:41 blomevero kernel: meson-mmc: >>>>>>>>hostbase ffffff800850c000, dmode
[amvideo..] saturation_post:0 hue_post:0 mab:1000000
Jul 24 10:34:41 blomevero kernel: meson-mmc: meson_mmc_probe() : success!
Jul 24 10:34:41 blomevero kernel: meson-mmc: >>>>>>>>hostbase ffffff8008528000, dmode
Jul 24 10:34:41 blomevero kernel: meson-mmc: gpio_cd = 1c1
Jul 24 10:34:41 blomevero kernel: meson-mmc: >>>>>>>>hostbase ffffff8008532000, dmode
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: trying cali 0-th time(s)
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[0]= 4400 padding= 3, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[1]= 4600 padding= 2, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[2]= 4400 padding= 3, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[3]= 4600 padding= 2, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[4]= 4800 padding= 1, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[5]= 4600 padding= 2, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[6]= 4600 padding= 2, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: delay[7]= 4400 padding= 3, bidx=4
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: calibration result : max(4800), min(4400)
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: line_delay =0x21101212, max_cal_result =4800
Jul 24 10:34:41 blomevero kernel: meson-mmc: calibration @0 times ok
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: base_index_max 4, base_index_min 4
Jul 24 10:34:41 blomevero kernel: meson-mmc: Data 1 aligned delay is 1
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: clk 100000000 SDR mode tuning start
Jul 24 10:34:41 blomevero kernel: random: fast init done
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: adj_win: < 0 1 2 3 4 5 6 7 >
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: best_win_start =0, best_win_size =8
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: clock=0x100024a, adjust=0x42000
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: clock =0x100024a, delay=0x21101212, adjust=0x42000
Jul 24 10:34:41 blomevero kernel: meson-aml-mmc d0074000.emmc: divider requested rate 52000000 != actual rate 50000000: ret=0
Jul 24 10:34:41 blomevero kernel: emmc: support driver strength type 1
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: try set sd/emmc to DDR mode
Jul 24 10:34:41 blomevero kernel: emmc: new HS400 MMC card at address 0001
Jul 24 10:34:41 blomevero kernel: emmc: clock 100000000, 8-bit-bus-width
Jul 24 10:34:41 blomevero kernel: mmcblk0: emmc:0001 AJTD4R 14.6 GiB
Jul 24 10:34:41 blomevero kernel: mmcblk0boot0: emmc:0001 AJTD4R partition 1 4.00 MiB
Jul 24 10:34:41 blomevero kernel: mmcblk0boot1: emmc:0001 AJTD4R partition 2 4.00 MiB
Jul 24 10:34:41 blomevero kernel: mmcblk0rpmb: emmc:0001 AJTD4R partition 3 4.00 MiB
Jul 24 10:34:41 blomevero kernel: meson-mmc: Enter aml_emmc_partition_ops
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: warning... response crc,vstat:0xa1ff2400,virqc:3fff
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: err: wait for irq service, bus_fsm:0x8
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: cmd 18, arg 0x12000, operation is in [reserved] disk!
Jul 24 10:34:41 blomevero kernel: meson-mmc: meson_mmc_irq_thread 2779 emmc: cmd:18
Jul 24 10:34:41 blomevero kernel: meson-mmc: meson_mmc_irq_thread() 2795: set 1st retry!
Jul 24 10:34:41 blomevero kernel: meson-mmc: retry cmd 18 the 10-th time(s)
Jul 24 10:34:41 blomevero kernel: meson-mmc: cmd_delay change to 2
Jul 24 10:34:41 blomevero kernel: meson-mmc: emmc: resp_timeout,vstat:0xa1ff2800,virqc:3fff
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmc_read_partition_tbl] mmc read partition OK!
Jul 24 10:34:41 blomevero kernel: meson-mmc: add_emmc_partition
Jul 24 10:34:41 blomevero kernel: hdmitx: system: plugin
Jul 24 10:34:41 blomevero kernel: amlogic mtd driver init
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p03] cache offset 0x000006c00000, size 0x000020000000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p04] env offset 0x000027400000, size 0x000000800000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p05] logo offset 0x000028400000, size 0x000002000000
Jul 24 10:34:41 blomevero kernel: aml_vrtc rtc: rtc core: registered aml_vrtc as rtc0
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p06] recovery offset 0x00002ac00000, size 0x000002000000
Jul 24 10:34:41 blomevero kernel: input: aml_vkeypad as /devices/platform/rtc/input/input1
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p07] rsv offset 0x00002d400000, size 0x000000800000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p08] tee offset 0x00002e400000, size 0x000000800000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p09] crypt offset 0x00002f400000, size 0x000002000000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p10] misc offset 0x000031c00000, size 0x000002000000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p11] instaboot offset 0x000034400000, size 0x000020000000
Jul 24 10:34:41 blomevero kernel: cectx c810023c.aocec: cec driver date:2020/03/16:reduece no msg in sleep time
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p12] boot offset 0x000054c00000, size 0x000002000000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p13] system offset 0x000057400000, size 0x000040000000
Jul 24 10:34:41 blomevero kernel: meson-mmc: [mmcblk0p14] data offset 0x000097c00000, size 0x00030c200000
Jul 24 10:34:41 blomevero kernel: card key: card_blk_probe.
Jul 24 10:34:41 blomevero kernel: emmc_key_init:183 emmc key lba_start:0x12020,lba_end:0x12220
Jul 24 10:34:41 blomevero kernel: emmc key: emmc_key_init:205 ok.
Jul 24 10:34:41 blomevero kernel: meson-mmc: amlmmc_dtb_init: register dtb chardev
Jul 24 10:34:41 blomevero kernel: input: cec_input as /devices/virtual/input/input2
Jul 24 10:34:41 blomevero kernel: cectx c810023c.aocec: not find 'port_num'
Jul 24 10:34:41 blomevero kernel: cectx c810023c.aocec: get sleep state error!
Jul 24 10:34:41 blomevero kernel: meson-mmc: calc 1323e695, store 1323e695
Jul 24 10:34:41 blomevero kernel: cectx c810023c.aocec: no periphs regs
Jul 24 10:34:41 blomevero kernel: cectx c810023c.aocec: not find 'output'
Jul 24 10:34:41 blomevero kernel: meson-mmc: total valid 2
Jul 24 10:34:41 blomevero kernel: meson-mmc: amlmmc_dtb_init: register dtb chardev OK
Jul 24 10:34:41 blomevero kernel: meson-mmc: amlmmc_ddr_init: register ddr_parameter chardev
Jul 24 10:34:41 blomevero kernel: meson-mmc: amlmmc_ddr_init: register ddr parameter chardev OK
Jul 24 10:34:41 blomevero kernel: meson-mmc: Exit aml_emmc_partition_ops OK.
