My Vero 4K crashes when I pause video content, or when I try to skip forward or backwards. At first I thought it was only with 4K content but today it also happened with 1080p content. I get the blue screen with the sad smiley and the device reboots.
I can’t really pinpoint when it first started or if something changed that caused this to happen.
@sam_nazarko do you know if there is anywhere that the progress of this can be checked as I have noted that it’s all my 4k files but only when the TRUEHD 7.1 audio track is selected?
If I select AC3 5.1 I can skip back and forth just fine which is a plus for now I guess
Hi, i think im experience this issue.
Vero4k
Kodi (19.3). Platform: Linux ARM 32-bit
Kodi x32 build (version for Vero)
Kodi compiled 2021-12-20 by GCC 8.3.0 for Linux ARM 32-bit version 4.19.152 (267160)
