Hi guys,
I’ve had my Vero 4K+ for about 3 months now and everything works fine unless I try to watch a movie in 4K untouched on my server. The Vero crashes after a while or pauses the movie or picture turns green or distorted. I also find the Vero to be very hot. I installed it in a open space, not in a rack or anything and it has the latest firmware. Note my Zidoo X10 plays the BD 4K just fine.
Any tips?
Thanks!
reproduce the issue
Well I uploaded the LOG, I played the same movie and it paused several times, when I stopped the movie Kodi crashed.
You have to paste/write the url here, so we can look at it.
We recommend people with 4K TV’s set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
The settings we recommend are as follows…
Settings>System>Display>Resolution> 1920x1080p
Settings>System>Display>Whitelist> (empty) *
Some televisions may also need, or benefit from, the following being set…
System>Display>Force 4:2:2 colour subsampling> (enable)
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K. *Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
I changed the settings as mentioned above. My skin is Aeon MQ8.
Still have pause problems in the movie, see log.
https://paste.osmc.tv/uqixuhip
There seems to be an issue with the log url you posted. Can you try uploading logs again.
Does your film contain a TrueHD track?
If you enable TrueHD passthrough, does the issue go away?
It’s just attached to my Panasonic FZ800, so not enabled.
I was planning to buy a second Vero 4K+ for my cinema room where I would enable TrueHD Passthrough but I still need to build the room because I just moved house.
Can you just enable it as a quick test? Mute the TV – or you’ll hear a horrible chopper like noise as your TV won’t be able to interpret the signal
I tried it enabling TrueHD passthrough and gotten no hickups or crashes. Is there a solution because I need to downsample to stereo?
Unfortunately this confirms an upstream bug in Kodi.
Hopefully there will be a solution in the near future.
After further testing I observed that my Vero 4K+ crashes alot while scanning or browsing my media library. I think it’s getting too hot when I leave it on, so now I disconnect it from the AC when not in use.
Works better that way although I think it could use a custom case with a fan. I’m browsing in 1080p but using latest Kodi with Aeonmq skin.
Has anyone else had this problem? The Odroid N2+ comes with custom cases and I just need a solution that works.
Thanks.
The 4.9 kernel comes with improved thermal throttling, so there may be some improvements there when this is released to stable.
It shouldn’t be getting too hot when idling. Do you have something that may cause excessive load, like an RSS feed enabled?
No massive loads but huge library on 100TB server, maybe this is causing problems too.
When I browse my movie library it often crashes and just freezes with no recovery. It gets very hot.
I think a custom case with fan would help…
I would look at producing logs before physically modifying the hardware.
