clegg
23 May 2019 04:30
1
Since upgrading to the latest Leia update (18rc3 I believe) any time i open a folder with a 100 or more jpgs (they may be high res 2160), my Vero 4K starts to load the small thumbnails of the photos but then will almost immediately lockup, and go to the blue frown face and restart. I have been unable to open really any photo folders unless they have under 10 or 20 pics since the update.
I did a fresh reinstall of the Vero 4K as I had some weirdness around the box in general. Since doing that everything is working much better but I am still seeing these weird photo crashing.
This a known bug right now? In advanced settings, I have ImageRes set to 1080, and UI res is set to 1080 (even though I am on a 4K TV).
to get a better understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here .
Depending on the used skin you have to set the settings-level to standard or higher , in summary:
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
clegg
23 May 2019 15:52
3
yep I’ll do that this afternoon!
clegg
25 May 2019 18:57
4
the logs were uploaded after the lockup and reboot @ upequjigaz for the code.
Not sure if after the reboot it sends the old logs or only the new ones after the reboot?
Last logs in the Kodi.old.log Are:
(and this is for opening folders with ~ 100-200 images in them each at higher res but low in size)
2019-05-25 12:18:14.559 T:2857046752 DEBUG: Finished background loading slot 1, 11: <redacted>040719-1249-DSC04021.jpg
2019-05-25 12:18:14.702 T:3044004576 DEBUG: CSMBFile::Open - opened smb://<redacted>040619-1238-DSC03423.jpg, fd=10002
2019-05-25 12:18:15.060 T:4051694304 DEBUG: LIRC: - NEW 1 0 KEY_ESC linux-input-layer (KEY_ESC)
2019-05-25 12:18:15.091 T:4072099840 DEBUG: HandleKey: menu (0xd8) pressed, action is Back
2019-05-25 12:18:15.092 T:4072099840 DEBUG: ------ Window Deinit (SlideShow.xml) ------
2019-05-25 12:18:15.092 T:4072099840 DEBUG: Waiting for BackgroundLoader thread to close
2019-05-25 12:18:15.092 T:4072099840 DEBUG: Stopping BackgroundLoader thread
2019-05-25 12:18:15.092 T:2857046752 DEBUG: Time for loading 12 images: 8781 ms, average 731 ms
2019-05-25 12:18:15.092 T:2857046752 DEBUG: Thread BgPicLoader 2857046752 terminating
2019-05-25 12:18:16.179 T:3044004576 DEBUG: CSMBFile::Close closing fd 10002
2019-05-25 12:18:16.180 T:3044004576 DEBUG: Caching image 'smb://<redacted>040619-1238-DSC03423.jpg' to '2/23623802.jpg':
2019-05-25 12:18:17.528 T:3044004576 DEBUG: cached image 'special://masterprofile/Thumbnails/2/23623802.jpg' size 1080x720
2019-05-25 12:18:17.687 T:4051694304 DEBUG: LIRC: - NEW 1 0 KEY_ESC linux-input-layer (KEY_ESC)
2019-05-25 12:18:17.710 T:4072099840 DEBUG: HandleKey: menu (0xd8) pressed, action is Back
2019-05-25 12:18:17.710 T:4072099840 DEBUG: CGUIMediaWindow::GetDirectory (smb://<redacted>EXport/2019/)
2019-05-25 12:18:17.710 T:4072099840 DEBUG: ParentPath = [smb://<redacted>EXport/]
2019-05-25 12:18:17.711 T:2857046752 DEBUG: Thread waiting start, auto delete: false
2019-05-25 12:18:17.729 T:2857046752 DEBUG: Thread waiting 2857046752 terminating
2019-05-25 12:18:17.743 T:3115311840 DEBUG: Thread BackgroundLoader start, auto delete: false
2019-05-25 12:18:18.044 T:3044004576 DEBUG: CSMBFile::Open - opened smb://<redacted>040619-1232-DSC03339.jpg, fd=10002
2019-05-25 12:18:18.055 T:3115311840 DEBUG: Thread BackgroundLoader 3115311840 terminating
2019-05-25 12:18:18.686 T:4051694304 DEBUG: LIRC: - NEW 1 0 KEY_ESC linux-input-layer (KEY_ESC)
2019-05-25 12:18:18.687 T:4072099840 DEBUG: HandleKey: menu (0xd8) pressed, action is Back
2019-05-25 12:18:18.693 T:4072099840 DEBUG: CGUIMediaWindow::GetDirectory (smb://<redacted>EXport/)
2019-05-25 12:18:18.693 T:4072099840 DEBUG: ParentPath = [smb://<redacted>]
2019-05-25 12:18:18.694 T:3115311840 DEBUG: Thread waiting start, auto delete: false
2019-05-25 12:18:18.794 T:4072099840 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-05-25 12:18:18.901 T:3115311840 DEBUG: Thread waiting 3115311840 terminating
2019-05-25 12:18:18.926 T:4072099840 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
2019-05-25 12:18:18.942 T:3115311840 DEBUG: Thread BackgroundLoader start, auto delete: false
2019-05-25 12:18:19.400 T:3099587296 ERROR: ffmpeg[B8BFF2E0]: [png] get_buffer() failed
2019-05-25 12:18:19.401 T:3099587296 ERROR: ffmpeg[B8BFF2E0]: [png] thread_get_buffer() failed
2019-05-25 12:18:19.401 T:3099587296 DEBUG: Error [-12] while decoding frame: Cannot allocate memory
2019-05-25 12:18:19.454 T:3099587296 DEBUG: LoadFromFileInternal - Load of special://masterprofile/Thumbnails/0/0b392aa1.png failed.
2019-05-25 12:18:19.525 T:3099587296 DEBUG: DoWork - took 1462 ms to load special://masterprofile/Thumbnails/0/0b392aa1.png
2019-05-25 12:18:19.525 T:3099587296 ERROR: DoWork - Direct texture file loading failed for special://masterprofile/Thumbnails/0/0b392aa1.png
2019-05-25 12:18:19.526 T:3099587296 DEBUG: GetImageHash - unable to stat url
2019-05-25 12:18:19.561 T:4051694304 DEBUG: LIRC: - NEW 1 0 KEY_ESC linux-input-layer (KEY_ESC)
2019-05-25 12:18:19.582 T:4072099840 DEBUG: HandleKey: menu (0xd8) pressed, action is Back
2019-05-25 12:18:19.681 T:3115311840 DEBUG: CSMBFile::Open - opened smb://<redacted>PC250225.jpg, fd=10001
2019-05-25 12:18:20.016 T:3044004576 DEBUG: CSMBFile::Close closing fd 10002
2019-05-25 12:18:20.017 T:3044004576 DEBUG: Caching image 'smb://<redacted>040619-1232-DSC03339.jpg' to '4/4dc87f59.jpg':
Edit - all the paths were edited/removed in this log upload.
We need complete logs, not just parts. Please follow the linked instruction to post complete logs.
clegg
25 May 2019 23:13
6
Was the paste upload not all the logs? it said it was… I know what I posted here was just a small section because I didn’t know if the “all the logs” actually uploaded the pre-lockup adn crash logs that are moved to .old ?
Can you clarify?
We need the link to the logs.
clegg
25 May 2019 23:28
8
I mentioned it above the code is : upequjigaz or… paste.osmc.com/upequjigaz or whatever the URL was.
The vero4k is running out of memory, but its hard to tell why; as the log provided is not complete.
Thanks Tom.
clegg
26 May 2019 18:31
11
Hmm, is there some other way I should be running the log collection? I ran it via the guide above (the GUI). Happy to get more info for you!
Please try getting logs again, and post the given link.
Thanks Tom.
