Vero 4k crashing when TV Tuner attached
https://paste.osmc.tv/oratijivem
When I attach my TV tuner stick (purchased from the OSMC store) the Vero crashes at random times. It used to work fine, but has started to cause the problems recently. I did a complete rebuild of the OS and still get the problem. Has my TV tuner fried?! Can we tell anything from the logs, or is the log overwritten when I restart after the crash?
Are you using a powered usb hub?
Thanks Tom.
No, should I be? The TV tuner is connected directly into the Vero.
Its recommended. Also I believe the latest version of OSMC draws a bit more power than older releases, which may explain why it used to work ok.
I use this, with 2 tuners:
Thanks Tom.
Thanks Tom. The order is placed!! Good to know that the new version is more power hungry as it helps to explain the possible change.
Great support as ever.
Dave
