So my vero 4k is turning off / or disconnecting, its in a remote room so only use it from SSH and as TVheadend server
I disconnected power and reconnected, after a min or 2 will disconnect again when i checked for updates it said it could do some due to time, checked system and it was 4 days out
so ive run the bellow
Sudo systemctl stop ntp
sudo ntpd -qg
sudo systemctl start ntp
ntpq -p
then did updates and all went through and everything seemed to be working for 30 mins, but now the system is showing time around 40 mins less than actual time, and its back to disconnecting, im on kernal 4.9
any other suggestions?
doing anything on SSH generally gives me a few minutes before i get disconnected
